Computers & Internet Logo
Question about Macally Computers & Internet
Macally mouse driver windows seven bluetooth
5 Related Answers
tom19511
Thomas Christopher
  • 1601 Answers
SOURCE: trouble pairing my bluetooth Macally BT micro mouse
Q: After pairing my mouse, the button click works but cursor tracking does not move. What can I do?A: The cursor tracking problem is because red sensor LED is not on. Please try another set of battery or fully charge battery again, and verify if bottom red LED turns on. If red LED still does not turn on, please remove batteries from mouse, press and hold the pairing button for 5 seconds, next press and hold the left and right buttons simultaneously for 10 seconds, followed by several clicks. Install the battery into mouse, you should see red LED turns on, mouse cursor will move.
Posted on Nov 23, 2007
tom19511
Thomas Christopher
  • 1601 Answers
SOURCE: Pairing my Macally BT micro mouse
tom19511
Thomas Christopher
  • 1601 Answers
SOURCE: configuring bluetooth 2.0 @ BtMico Mouse
Not supported for VISTA yet.
Anonymous
  • 661 Answers
SOURCE: the mouse was working with windows seven and now
These things are always a bit touchy and I havent worked with that exact model but I have seen the problem before.
The base(reciever) unit is USB right? If so unplug the base unit and wait a bit and plug it back in. If windows does not autorecognise the mouse try unplugging it again and rebooting the machine. After it reboots trying plugging it back in. Windows should recognize it. If not, make sure that the base unit and the mouse do not have some sort of buttons you need to press to get them to syncronize.
Try uninstalling the drivers and unplug the mouse and reboot. Then try setting it up like a new mouse. If that doesnt work try new drivers from Logitech. If that still doesnt work then there could be a problem with the mouse or a problem with a corrupt entry in the registry.
I am no prepared to take the risks of stepping someone through editing the registry so I hope one of the options above fixes the problem.
Posted on Mar 13, 2010
Ezrahite
Rofel Lantican
  • 2632 Answers
SOURCE: I have a Dell XPS
Welcome to Fixya. If you have isssue with the bluetooth connection of your Keyboard and Mouse then all you need to do is to use the guide provided below to fix the issue. You also need to make sure that the driver for your bluetooth device is already install on the system
Dell XPS 420 Drivers
Resolve Bluetooth mouse or keyboard failure to function - Microsoft (Refer on Method 4)
Mouse, Keyboard or Touchpad Not Working Correctly - Dell (Refer on Issue 2)
Hopefully the problem will be fixed.
Thanks for using Fixya.
Posted on Feb 27, 2011
I'vepurchased a bluetooth wireless laser mouse and can't figure out how to instal
You have to to turn on the "find me" button on the mouse. It is usually a pin sized hole (see your manual) once you have the find me button on goto the bluetooth manager on your PC or Mac and link the 2. Sometimes it will ask you for a password, the default is usually 000 but again refer to the manual. If you don't have one paste your question on your google browser
2answers
Need driver
in the dock click on system prefs and go to the keyboard and mouse bit and see if you can select it. with it plugged in click the apple menu, click about this mac and a window will appear, click the more info button and in the window that appears click usb and see if it is listed, if not the mouse is iffy
1helpful
1helpful
Trouble pairing my bluetooth Macally BT micro mouse
Open Questions:
Top Macally Computers & Internet Experts
Paul Bade
Mike
ADMIN Andrew
ADMIN Andrew
Are you a Macally Computer and Internet Expert? Answer questions, earn points and help others
