Question about LG LHY-518 System
I need the system cable for lg lhy-518
Cable that goes from dvd/vcr to the subwoofer
3 Suggested Answers
6ya staff
SOURCE:
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: I have a LG LHY 518 system and the subwoofer
I'd lurk on eBay or other auction sites and see if one becomes available.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/LG-LHY-518-Home-Theater-Systems-manual/id/366ag212/t/2/
LHS-95PAA
Take a clue from that non-standard system cable between the electronics and the sub. It powers the sub's amplifiers and carries signals. Wanna take a chance on the pin-assignments being consistent across all product lines?
Posted on Mar 13, 2011
Testimonial: "Informative"
SOURCE: i need remote codes for
hello after a long search through the net the only solution to retreive the code is through LG themselves you will need to send them an email with your dvd model they will email you the code
another solution would be to purchase a all in one remote this i think would be best as the codes come in the manul goodluck
Posted on Mar 28, 2011
I have a sb wa340 active subwoofer. I have subwoofer and speakers but I don't have DVD how can I use this
So is the DVD part missing? There is a VCR / Aux input on the back but it is for audio only. There are no video inputs so if the DVD is not included in your sub/speaker system, you'll be limited to audio only. First, you'll need to connect a TV to your system using one 'Video Out' cable methods so you can see the menu for the remote control changes on the system. From here there are 2 options:
  1. Connect up a working DVD player directly to your TV using the best option available. Use the audio outputs on your TV to connect to the VCR or TV input on the system box. (Using standard RCA cables.) You may need to enable the external audio outputs on the TV. (Check the setup -> audio menus etc.)
  2. You can use this as an audio amp by connecting a RCA cord from the a DVD R/L audio outputs to the VCR-Aux input on the amp box. You will need to run a separate video feed from the DVD directly to your TV. (Select the desired input on the TV to watch a DVD.)
You'll need to do a lot of switching back and forth with multiple remotes to get everything working, but the speaker setup can be made useful if it still works.
Here is a manual for the system: http://service.us.panasonic.com/OPERMANPDF/SCMT1.PDF
Mar 13, 2015 | Audio Players & Recorders
How to change sylvania tv to video without remote
I was able to get the Sylvania TV to accept a different input (the remote was lost) by connecting the DVD to a Sony VCR using composite RCA jacks then connecting that to the TV. You'll need two 3-jack (yellow, white, red composite) cables - cheap at any store. Here;s how:
1. Connect RCA output jacks from the DVD to the input female receptacles of the VCR (first cable).2. Connect output jacks from VCR to the female input jacks on TV (second cable). 3. Turn on all equipment (VCR, DVD, TV)4. Switch the VCR to "Line 1" (for my Sony VCR, this shows up as "L1") by pressing the TV/VCR button on the VCR remote (which I did have).
Your system should now work.
The principle is to "fool" the TV into thinking that it's primary input is through the RCA composite A/V jacks rather than the cable connection. No need to disconnect the cable at any time. Any functioning VCR should work well as long as you have the remote for that device. Remember, connect output on the DVD to the input on the VCR, then the output on the VCR to the input jacks on the back of the TV. If you have the connectors on the TV, VCR, and DVD, component cables should work as easily. Remember, output from the DVD goes to the input of the VCR. Theoutput from the VCR (for which you DO have the remote) goes to the input side of the TV.
Apr 07, 2012 | Sylvania Televison & Video
Just purchased a Magnavox vcr/dvd player and cannot hook up to our cable box
You have a line coming in to the box for the cable and a line going out to the Tv. The line going out to the TV goes to line in on the dvd/vcr and the line out on the dvd/vcr to the TV.
Dec 10, 2009 | Philips Magnavox DVD/VCR Dual Player
Vcr/dvd player will not let me watch cable through it
There should be video in and video out on the dvd player. You shouldhave the wires going from video out on the cable box to video in on the vcr. Then you should have video out on the vcr going into the tv
Aug 13, 2009 | Samsung DVD-V5500 DVD Player/VCR
On the back of the VCR are two cable attachment
SIMPLE: the one that says VCR OUT goes to the TV IN , and the DVD OUT goes to the VCR IN , THANKS AJ
Aug 08, 2009 | Televison & Video
Tv/digital converter box & vcr-dvd hook-up
ok cable sat wire goes into input of dvd-vcr input then coming out from the dvd vcr and into the moulator then a wire out to the tv now make sure your vcr is set to the right setting ...now you can record 1 cable..2.vcr dvd..3 modulator...4...tv make sure vcr is set to monitor
Dec 04, 2008 | Philips Magnavox DVD/VCR Dual Player
Usually a cable box has a RF (antenna connect) IN (from the external signal) OUT (cable going to the TV_RF in)
Usually one has to place TV_channel on 3 or 6 (my TV ch. 60).
EXTERNAL signal goes in CABLE box RF_in, CABLE box RF_out to the TV (RF_in).
In order to connect DVD/VCR, [IN LINE with cable & TV] just connect the RF_out from CABLE BOX into the RF_in of the DVD/VCR, RF_out of DVD/VCR to the TV RF_in.
Jul 24, 2008 | Philips Magnavox DVD/VCR Dual Player
How to connect my dvd & vcr with the converter box
Here is my setup.
1) Separate DVD player 2) Separate VCR 3) Digital to Analog Converter box 4) Analog TV 5) Rabbit ears (UHF/VHF) antenna
The antenna goes into the converter box.   The RF-output of the converter goes into the RF-Input of the VCR The DVD output goes into the front input jacks of the VCR The VCR RF-output goes into the TV RF-Input The VCR Line output goes into the front of the TV
To watch DVDs, we turn on the DVD player, turn on the VCR, and set the VCR channel to L2, and tune the TV to channel 3.  The converter is off.
To auto record on the VCR, the converter must be tuned to the station being recorded.  The converted must be turned on, the TV can be off.
To watch VCR tapes, turn the TV and VCR on.  The TV is set to channel 3.  Just press play on the VCR.
To Watch TV.   Turn the TV and converter on.  The TV is set to channel 3.   Change the stations using the converter.
May 06, 2008 | Insignia Digital-to-Analog Converter for...
Connecting dvd/vcr combo with tv and digital cable box.
You trying to put the DVD/VCR combo between the cable box and the TV? OK, cable out goes to vcr in, vcr out goes to tv, I think you got that. Now there should be a tv/vcr button on the vcr/dvd, you need to press that when the unit is on. Also, make sure you are on the correct input on both the vcr and the tv, usually video 1 or AUX and choose line in or L1 on the vcr/dvd. If the tv/vcr button is toggled, itll completely bypass the vcr/dvd player.
Mar 03, 2008 | Toshiba 32A41 32" TV
Onkyo TX-SR304
Onkyo offers access to manuals at their web site. HERE is a link to the receiver line.
Personally, I'd connect the speakers to main left/right. The subwoofer to subwoofer out. The Go VIdeo unit to VCR/Video 1, the cable box to Video 2 and the video output to the Sony TV composite input. No need to connect the TV audio out to the receiver since the audio feed comes from the cable box.
Jan 13, 2008 | Onkyo TX-SR304 Receiver
LG LHY-518 System Logo
98 people viewed this question
Top LG Audio Players & Recorders Experts
Marvin
Marvin
PNiss
patseamur
Level 1 Expert
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
