Epson PowerLite® 83c LCD Projector Logo
A
Anonymous Posted on Jun 09, 2012
I changed the bulb on my epson powerlite 83+ and now there is a blurry spot in the middle of my screen. Is there anyway to fix this?
I have cleaned the filter, reset to factory settings, tried a different bulb to make sure the bulb wasn't faulty, and I have cleaned the lens.
Wes atPCC
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Apr 02, 2013
Wes atPCC
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2326
Points
For anyone that may still stumble on this post, we have two of these and the blurry spot is most likely caused by the neutral density filter in front of the Green LCD element. We still haven't found a source for this part, but it seems to be caused when the bulb overheats and melts the plastic filter causing it to warp and wrinkle.
4 Related Answers
Anonymous
  • 57 Answers
  • Posted on Aug 15, 2010
SOURCE: Total factory reset Projector Epson Powerlite S5
This is an anti-theft device, you will need to contact Epson if you cannot recall your password.
Anonymous
  • 110 Answers
  • Posted on Aug 22, 2008
SOURCE: Epson PowerLite S1+
You have not set the port on the back of the projector settings.
Go into the projector menu and go into the IMAGE area. Somewhere in here you should be able to select computer.
Anonymous
  • 682 Answers
  • Posted on Mar 14, 2008
SOURCE: Looking for Repair Manual For Epson Powerlite 730
http://www.eserviceinfo.com/downloadsm/25707/Epson_EMP-720,%20EMP-730.html
Alan Rothery
  • 109 Answers
  • Posted on Jun 04, 2009
SOURCE: Epson 83+ powerlite projector overheat
hi follow the link bellow the instructions are on page 83 \\files.support.epson.com/pdf/pl83pl/pl83plug.pdf
Epson projector center blurry
Sounds dumb on this one but make sure the lens is cleaned. Other then that check the manual for operating range of lens to screen. Typically somewhere in the area of 8 to 12 feet.
Changing the bulb on a epson powerlite
Original lamp USD110
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
1helpful
After changing light bulb , purple spots still there
you need to clean the backside of the LCD and the LENS ... on the inside. get a service manual off the internet and have fun...it is hard to do.
My Epson PowerLite 1725 projector has a wide green bar displayed in the middle of the screen with a purple shadow on its right. Do you think a bulb replacement would fix it?
im afraid that sounds like some dead pixels. and if thats the case then no a bulb wont fix it. call epson tech support and see if they will replace it for free.
One of our Epson PowerLite projectors was working
We found that the bulb was dim because it was about to burn out. The projector's filter han't been kept clean, causing it to run hot, which in turn shortened the bulb's life.
2answers
Epson PowerLite 83+ goes completely green or red
make sure the signal matches. you could reset the settings to factory default.
Images has a blue color across the center
Wow, 3 in a row. As described on 2 other projector issues this is very similar to those others. I'll repeat the info here.
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the blue color has gone out. The image is made up of red, green and blue images layered upon the screen. If the blue panel has gone out then there is nothing filtering out the red light in the image.
It looks like yours has just a secone of the panel dying or comming loose from it's connector.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
2answers
Projector Lamp is flashing Red
if you know how to open the unit, try fixing its ventilation. flashing bulb light sometimes mean an occurance of overheating. try to clean all the fans and the air vent.
HP vp6162 projector spots on projected image
you may have touched the bulb while changing it and minute traces of skin oil are on the actual bulb, with the machine cold, try and very carefully clean the bulb
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
