Download its installation manual from here and refer it for details about connections.
SOURCE: NO RECORD
You need to use an audio CDr, data or computer CDr's will not work in this machine.
SOURCE: Wurlitzer New York Model CD Jukebox Manufactured around 1992
How do you get the arm back over the carousel so you can play a CD initially?
The gripper motor is powered by the K6 switch which is a copper wiper ring you can see at the end of the gearbox. If that is dirty or has a dead spot it will stop the motor before it should.
SOURCE: Song Programming
With regards to your problem with the Rowe Ami 100 cd jukebox.
Do you have a manual, if not I suggest you buy a printer manual or one on CD and refer to the Programming and Installation section.
In order for the jukebox to know about the cd's that are installed in the jukebox it has to initialize all or the changed cd's that have been replaced within the jukebox.
Put the jukebox into the Service Mode (the service mode should appear on the display)
Type 3 to select the Initialize sub menu
Type 0 and full initialize will appear on the display
Press Popular to start the initialization
Place the jukebox service switch into the normal mode
Initiazation will take around 30 minutes to complete.
Regards
Alan Hood
ami-man
SOURCE: amplifier schematic diagram
Hi Janet,
If you get back to me with your email address I will scan the schematics and email them to you.
Regards
Alan Hood
ami-man
UK
[email protected]
SOURCE: Seeburg Stereo Phonograph Model ESL100 Q-65-H5
End of record switch out of adjustment or bad? Disconnected?
Thank you for the suggestion Gopakumar, but the link was not to the right manual, and i do not have permissions to access the page further.
[email protected]
