SOURCE: my hayward super pump has a wiring diagram but it
Is one screw silver and one brass? Or are they both silver or both brass?
SOURCE: Need wiring diagram for Hayward dual Super 2 speed
You need 4 wires to wire the 2 speed pump. You will also need a 2 speed time clock.. Tightwatt or intermatic. The wiring diagram is on the motor.
SOURCE: looking for a diagram on a hayward pool pump
What specifically are you looking for (beside the fact you asked for a diagram)?
It should be setup for 220 Volts ... the only thing inside is a start cap.
Can you tell me more? I maintain 5 2 and 1 1.5 hp such pumps.
SOURCE: I have a Hayward 1 HP pool pump. I have to
hi ...the two yellow go on one side of the cap and the red /white go on the other.. like two on the negative side of a battery and one on the pos .. your pool pump repair guy longwood fl
SOURCE: I'm need assistance wiring my hayward 2 speed
You may have a faulty bearing ... causing the noise. The pump is actually water cooled. Do you have 2 inch line for your 2 HP pump? Small pipe makes the pump work harder. If your lines are smaller, you may want to consider a smaller pump.
the motors will run pretty warm.
Run your pump on high for best results.
If you are using a timer ... you will need a double pole switch to turn it off if it is setup for 220 VAC (which it should be, for most econimical operation)
