Question about Kenmore 53092 / 53094 Side by Side Refrigerator
Kenmore 795.5102 Ice has a bad taste immediately after being dumped, so it's not from freezer smells. Had fridge for a year and has always been this way. Water from fridge door is fine, but chan
It's not caused by freezer odors. Had fridge for a year and has always been this way. Water from fridge door is fine, but changed the water line to fridge anyway. Ice still bad tasting. I've seen others complain about this, but have seen no answers; except for one person who suspected the ice maker valve. Does anyone have a solution?
5 Related Answers
francis rivero
  • 958 Answers
SOURCE: Bad water & ice cube taste
then change your filter. the new filter could be different with the old filter. check the new filter, see if there is odor removal and taste removal with it.
if not then get the filter with carbon filter, odor and taste removal.
then with a new filter, run about 5 gallons of water before using the water for drinking.
tnx 4 using fixya,
drcool
Posted on Oct 07, 2008
Anonymous
  • 750 Answers
Hello redwood City
Welcome
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You replaced the copper tubing which delivers the water to the fridge and that didn't help. You replaced the copper tubing again with plastic tubing...no better. Any suggestions? Your tap water doesn't taste this bad.You bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. And your tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
Off-taste, odor or gray color in the ice
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
may need to be installed to remove the minerals.
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
HUUUM!!
Please remember to leave a rating.
Posted on Oct 12, 2008
peyton32034
peyton thompson
  • 410 Answers
SOURCE: Bad tasting water and ice from refridgerator.
i agree with rpbuice but in addition to flushing the water line you may need to replace the line then using the water dispencer run out about a gallon of water thru the door. this will clear the reservoir of bad tasting water. for the i/m throw out all of your ice then let it make a couple of batches and throw out that ice as well be sure to clean your ice bucket very good to remove any lingering tastes from the old ice.
fyi bad tasting water is generally from bad water supplies. good luck..
Posted on Jan 20, 2009
Anonymous
  • 1550 Answers
SOURCE: I have a bad smell and taste in water and ice from fridge/freezer
Take out all shelves and accessories that can be removed. Wash these thoroughly with a mild detergent (dish washing liquid and warm water) and rinse thoroughly. Allow them to air dry completely.
* Wipe the inside walls of the refrigerator and freezer down completely with a solution of 1 quart warm water and 2 tablespoons of baking soda. Wipe the walls completely dry.
* Leave the doors standing wide open. Use a fan to circulate air through the cabinets for several hours to completely dry the inside walls. After several hours, turn the fan off.
* Replace the shelves in the refrigerator. Place shallow trays of one of the following deodorizers on the shelves of the refrigerator and freezer:
o Baking soda
o Activated carbon (used in aquarium filters, can be obtained at a pet store)
o Cat litter
o Fresh and unused coffee grounds (this may leave a coffee smell that would dissipate after several days)
* After 24 hours, plug in the refrigerator and allow it to cool for several hours with the deodorizer still in place. Once cooled to normal operating temperature, remove the trays of deodorizer and put your food back into the refrigerator and freezer.
* Keep some cereal size bowls of a deodorizer in the freezer and refrigerator cabinets for several days
Posted on Feb 28, 2009
wecandoit
Ragh Puldit
  • 10 Answers
SOURCE: smelly water from door dispensor
I had the same problem. Drove me crazy and cost me about 5 filters at $50 a pop until I found the solultion. Water in the Sears/LG refrigerator that I have (french door trio) goes through the filter then into a container on the left front door of the refrigerator. That container stores the water so it can get cold and it also equalizes the flows in the system so that when you put your glass under the spigot the flow is steady and the water is cold. Problem is .... this tank can build up with algae/slime/foul tasting stuff. Since it is after the filter, no matter how many times you change the filter it will have no impact on the water in this container. That is why if you use the water spigot a lot, the water seems to get a little better (as the tank water gets diluted) but as soon as you don't use it for several hours or more, back comes the smelly water again. Solution for me was to remove the plastic panel on the inside of the left front door and clean the plastic bottle. It is pretty easy to remove with 2 screws and easy to pull off the hoses. I filled is with a little clorox and water and swished it around for several minutes then drained and rinsed it. Then I filled it again with a little clorox (like an ounce or two max) and put the container back into the fridge. Once in the fridge, I ran fridge water through the front water dispenser for about a gallon or so. This flushed out the chlorine in the plastic container as well as the lines between the container and the spigot. After about a half hour of work, my great tasting water in the fridge is back again. I've checked the taste on this water for several weeks now and no plastic/odor/bad tasting water any more. Hope this helps.
Posted on Mar 12, 2009
Bad tasting ice/water/food
Have you put a few boxes of baking soda in the fridge to absorb the pungent odors? Do that.
Jul 07, 2017 | Kenmore Side by Side Refrigerator
Ice tastes bad
If It were me I would change the filter in the fridge, that always worked on mine.
Dec 03, 2013 | LG LRFD22850 Bottom Freezer Refrigerator...
I saw your response to another Kenmore frig and I have a similar problem I want to ask you about. I have a Side-by-side Kenmore frig(model 106.9555722) that we've had for 16 years!! Other than r
I have seen this one other time in all my years of appliance repair and changing out the "water inlet valve" corrected the problem. I don't have an answer to why it did, but it did. Here is the valve for your unit.
After you change the valve be sure to purge the water line for a good 5 - 10 mins to get all the nasty water out. Keep me posted!
Nov 24, 2012 | Kenmore Side by Side Refrigerator
Freezer area smells and ice cubes and butter taste off?
It sounds like the ice maker if equiped. Remove Ice bin and clean out,and try a lite spray of bleach or vinegar (don't mix) If the smell is still happening and comming from ice you may want to install a inline filter.
Jul 26, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Have a Kenmore model 106.5702602 side-by-side for 1 year and can't get rid of freezer odor...have tried everything and can't put anything in freezer that isn't affected by this smell. Help!
the air blows from freezer to fridge side and then returns from fridge to freezer,so it could be and usually is something on fridge side causing odors or funny tasting ice cubes,check under bottom draws on fridge side,what kind of odor is it?
Nov 28, 2009 | Kenmore Refrigerators
ICE CUBE MAKER SMELLY ICE CUBES
your model will have a filter for it. it is located usually on the fridge side torwarss the top back of the fridge. it sounds like you need to replace the filter. it needs to be replaced every 4 monthes or so to keep the water clean. also you may put some water in a cup from the tap/faucet and make sure it is not the water it's self. if it is you may want to think about also having a water filtration system installed in your home.
Jan 07, 2009 | Refrigerators
Hello margrek
Welcome,
YOU SAID, YOU HAVE KENMORE ELITE BOTTOM FREEZER WITH ICE MAKER THE ICE CUBES SMELL HORRIBLE ALWAYS, I EVEN TOSS THEM OUT EVERY FEW DAYS, STILL SAME PROBLEM
Ice has bad odor and taste.
1• Ice has picked up odor or
flavor from strong food stored
in refrigerator or freezer.
2• Water running to ice maker
has poor taste or odor.
3• Ice not used frequently enough.
4• Cover foods tightly. Discard stale ice. Ice maker will
produce fresh supply.
5• Add filter to water supply line. Consult a water purifying
company.
7• Discard stale ice.
Huuum
Please remember to leave a rating!
Oct 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Hello redwood City
Welcome
You said,
copper tubing."
Whirlpool remedy
Thank You ,
HUUUM!!
Sep 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 53092 / 53094 Side by Side Refrigerator Logo
73 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
John Tripp
John Tripp
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
