I have this processor (Intel SL88S Pentium D 3.0GHz 2M 800 Socket 775 Dual Core) and 4 gig of DDR3 but my games are laggy and unplayable at times.
RAM is not likely your problem. What games are you trying to play? It could be that your graphics card is underpowered for the games you are playing. You are not using your motherboard's built in graphics I hope. It could also be that your entire system us underpowered. You should check the minimum and recommended system specs for each game to make sure your machine is up to par. Even if it meets the minimum specs, you'd do well to make sure your system is more powerful than that as you will not likely have the best experience and will not be able to run the games at higher resolutions.
SOURCE: Will this CPU be compatible with this MOBO?
Okay your Processor is not supported by your System Board. I will take some time and look to see what would be a good upgrade, but it may take a few days.
Ryan Frame
Creative Energy Associates Technical Center
SOURCE: Motherboard suppord CPU
google the mother board and then read the book for the board. it should list the compatable cpu's then you can log on to www.geeks.com and search for the cpu you want that will work with it.
SOURCE: is it compatible a intel dual core processor to a
Sorry man, that board's highest cpu is Pentium 4.
To get more kick out of it, you could upgrade the RAM to 2Gb.
SOURCE: Can a Foxconn G31MV-K work with a Intel Pentium Dual Core 2M/800
Yes. This motherboard can work with the Intel Pentium Dual Core 2M/800 E5200 (2.5G) processor.
Below is a link to a page that lists the specs for this motherboard:
http://www.foxconnchannel.com/product/motherboards/detail_spec.aspx?ID=en-us0000376
SOURCE: are you sir intel processor e5300 2.6 dual core,
I already Corrected Myself as i said, it is NOT COMPATIBLE.
Thanks!!
