When i format the memory card using phone then, my memory card show full. Sometimes i can not see my memory card in the mobile. One month ago i face a problem, when i use camera to take any picture to save it in external memory then i gate a message that external memory is full. But the external memory is not full.
SOURCE: External memory card for LG kc550 won't work
I was also getting bad format error on my LG kc550. Did a little research (read the instruction book) and if you want to properly format your card to work with the phone you must insert the card into the phone then connect the phone to your computer via the USB cable supplied. Go to "My Computer" and you should see that the phone and memory card are displayed as two separate external devices, when you try to access the memory card your computer should ask you to format it. Click Ok and a Format box will come up, click Ok again and your computer will format the memory card acordingly.
Unfortunatly this resulted in my losing 4gb of space on the card, i dont know wether its based on percentage or a fixed amount the phone needs but if thats the case you will need more than 4GB for your card to be formated for your phone
SOURCE: My LG enV phone problem
Wow. Some of you are retards, sorry, but you don't know how this phone works.
A) Auto-Save if for SENT messages only. If it is on, it will save your sent message in the sent box. if set to off, then it will not show any sent messages. If set to prompt, then it will ask you after the message is successfully sent from your phone to the Verizon network.
B) Auto-erase is for INBOX only. It will automatically erase the last message in your inbox when it reaches it's max capacity.
C) The LG EnV can accept up to 4GB of memory. (hollowtech2, you are the ****** i mentioned above, don't pur information you have not confirmed. people will dissprove you, and you will be embarrassed.)
D) i am still looking to solve the text messgae save limit problem. i will post it when i find out.
SOURCE: LG VX10000 need2 download or save text messages to a memory card
You can use Bitpim to download your text messages off your phone to your computer. If you want to learn about Bitpim go here: http://www.lgvoyager.com/wiki/LG_Voyager_Hacks
SOURCE: Not enough Memory, LG Renoir camera
From the settings menu, choose phone settings, then Memory Manager.then handset common memory. Chances are, this will nearly all be used up. Move any pictures, video, music etc from the internal memory to the external memory card using the My Stuff application, then move to external memory. This should solve the problem & any new photos will be stored on the external card. When theinternal memory gets full, the Renoir does funny things!!
SOURCE: Can't save music to external memory
ive been trying for ages to do this and its so easy but no one seems to be explaining it easy! Your phone without the memory card only holds one or two songs. you must have songs in there for it to say memory full. Go to this song press options , file, move to extrenal. Now try and send a song through bluetooth. You will be able to recieve it now you have freed up spave on the phones own memory. Remember to save it to external straight away so u can recieve the next item. Easy peasy!
