How to light pilot light
SOURCE: vulcan 148l oven burner will not light. pilot on.
Yes.
Over time, thermocouples erode in pilot flames and when they no longer reach the pilot light they need to be replaced. Check the thermocouple mountings as well: some ham-fisted amateurs try to bend the probe back into the pilot light and break the mountings. The pilot light jet will also need to be checked to ensure that it is clean and that the pilot is burning correctly.
Note that as with all gas appliances, repairs should only be carried out by qualified gas fitters who have the tools and knowledge to leave your appliance in a safe condition. In many countries it's a legal requirement. My reply is therefore given on an informational basis only as poor workmanship on gas appliances is directly attributable to many
deaths every year.
Posted on Mar 16, 2010
SOURCE: Noisy pilot light Vulcan Quasar 40
Simply clean out the jet tube with a fine wire, the sound you hear is the gas blowing by the irregular edges, and swirling and not mixing and producing sound waves, (Bit like a flute) So, you need to clean the tube right out, and smooth off the end again, & sorta "Countersink", Flame the end too, at the end.use a very fine needle file, and make it look like new, that will sort your problem out. Then adjust so you have a good gas flow. Also check out it isn't blocked too.
Posted on Apr 30, 2010
SOURCE: The pilot light of my
Hi.
Air duct must be checked. Poor ventilation is common cause for the problem.
If ventilation is OK, then the other possible cause is a defective flame sensor. The flame sensor is connected in parallel with the valve solenoid. For safety reasons testing must be done by a technician.
To get a quote on repair ring the service number listed on the user manual.
Posted on Sep 13, 2010
SOURCE: how do you find and lite the ilot light on a vulcan compact 60 heater
try with www.amazon.com
God bless you
Posted on Jul 21, 2013
Apr 09, 2016 | Vulcan Heating & Cooling
Jul 20, 2013 | Heating & Cooling
Mar 23, 2013 | Williams 1403622 Gas Compact Heater
Jan 15, 2013 | Heating & Cooling
Sep 24, 2010 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
Sep 13, 2010 | Heating & Cooling
Jul 04, 2009 | Vulcan GCO2D Gas Single Oven
32 people viewed this question
