Sony Cdx-gt56ui In Dash Car Cd Player W Radio Receiver Head Unit Aux Input Logo
Robert Copeland Posted on Jun 09, 2012
Which wires do I use for the acc/battery on Dodge Dakota for Radio
Trying to connect new radio in 07 dakota, cannot figure out which wire in the dakota does the sony yellow (battery) and red (acc) connect to?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 09, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
413
Points
One wire stays hot all the time (yellow) and acc is only hot when the key is on. you should be able to find the wires in the original wire harness to the old radio with a test light or a meter.
1 Related Answer
cazimmer
  • Posted on Apr 09, 2008
SOURCE: Sony STR-DE310
Our Sony STR-DE310 displays the message "Protected" and will not operate. We have not used it for awhile, but it worked finte the last time.
1991 Dodge Dakota factory radio went bad so would I be able to wire in a 2004 Chrysler 300 factory radio ?
05 's anti theft not compatible to 91 but here are the wiring diagrams https://www.modifiedlife.com/1991-dodge-dakota-stereo-wiring-schematic/ https://www.modifiedlife.com/2005-chrysler-300-car-stereo-wiring-diagram/
2006 dodge dacota radio wiring harness
2006 Dodge Dakota Car Stereo Wiring Guide
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Dark Green/Brown
Right Front Speaker Positive Wire (+): Gray
Right Front Speaker Negative Wire (-): Gray/Brown
Left Rear Speaker Positive Wire (+): Dark Green/Dark Blue
Left Rear Speaker Negative Wire (-): Dark Green/Orange
Right Rear Speaker Positive Wire (+): Gray/Dark Blue
Right Rear Speaker Negative Wire (-): Gray/Orange
1helpful
1997 dodge dakota truck radio stereo audio wiring diagram
1997 Dodge Dakota Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red/Blue
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Black/Yellow
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Brown/Yellow
Right Front Speaker Negative Wire (-): Brown/Light Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White
Left Rear Speaker Negative Wire (-): Dark Blue/Red
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Brown/Orange
Also, this coudl be interesting: Dodge Dakota Trucks at 1996
Hope helps (remember to rate and comment this answer).
3helpful
Radio wiring troubles for 1992 dodge dakota le
hmm well there are 2 solutions to this that i can give cause i dont have the wiring diagram for that truck..
The first would be to set with a multimeter and test the wires under the dash for the hot, and axcessories wire.
The second would be to run 2 wires directly from the battery to the inside of the vehicle and connect the radio using that.
The second solution is self explained so lets discuss the first.
The truck came with an original radio. connected to this raid is a jack with a bunch of wires. remove the connector. with keys out the ignition test every wire until you get 12V.. thats your hot wire. this wire always has power. Now lable that wire and push it aside. turn the ignition on and test the remaining wires until you get 12v .. thats the ignition wire or acesories. this only has power with the ignition on. The remaining paired wires are for the speakers. connect the new deck and vonnect the wires one pair at a time to determine their location. or ypu can look at the wires connect directly to the speakers to see which wires go to which. .. you can use the body of the truck as a ground.
New Radio Extra wires & No Power
the solid black wire goes to earth on the steel sub structure of the dash and if you plug the aeriel in and it should power up what sort of radio is this
will it power up at the moment blck wire is always an earth to dash what sort of stereo is this
1helpful
2answers
How to put a cd player in place of factory stereo in 1994 dodge dakota. Need wiring diagram in color.
usually you can buy an adapter that will plug into the factory wiring i picked mine up at wallmart
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
