Sony Str-k750p Av Reveiver Logo
Anonymous Posted on Apr 02, 2017
Why does my Sony STR-K750P AV receiver automatically switch to Video 2?
My Sony STR-K750P automatically switches to Video 2. I select a different input, DVD, Video 1, CD, etc, but within 3 minutes, it will switch back to Video 2. It might take 10 seconds or it might take 3 minutes, but it always switches back to Video 2. I have my Sony KDS-55A2000 TV and a Comcast Scientific American cable box hooked up and a DVD player hooked up to the receiver. I've tried to use RCA cables and optical on Video 2 to see if that made a difference. I've also put my DVD player on Video 2 input instead of my cable box, but no matter what I do, it's the same story, it switches back to Video 2. Has anyone else had an issue like this before?
Jerry Greenberg
Level 3:
Genius:
  • Sony Master 1,691 Answers
  • Posted on Apr 02, 2017
Jerry Greenberg
Sony Master
Level 3:
Genius:
Answers
1691
Questions
Helped
735609
Points
3767
Some models of systems will switch to a new source automatically if the source sees a new signal coming on. Try disconnecting the device on your Video 2 to see if this is the case.
I have seen the IC or component(s) in the switching circuits become defective and cause unpredictable or faulty operation. This can also be a fault condition you are seeing.
2 Related Answers
Anonymous
  • 10594 Answers
  • Posted on Jan 04, 2009
SOURCE: sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
mlapres
Mike LaPres
  • 757 Answers
  • Posted on Jun 18, 2009
SOURCE: Sony PCM 48 Issue
As long as you continue to have both HDMI and optical outputs connected at same time from the cable box, it will probably always choose the default as HDMI. If you do not want to change any connections then the best thing to do in this case is to always leave the cable box turned on. Otherwise, disconnect the HDMI and connect it to the TV by component video.
1helpful
I have a Sony STR-K750 receiver running with a Samsung 50 inch series 6 tv.There is a digital lead running from the Austar receiver to the Sony receiver for sound.I have a Hdmi lead running from the Austar...
Run both audio and video to the tv, then use the tv optical audio out to go back to the receiver. The problem is, when you split the signal, the tv takes longer to decode the hdmi signal =, thus delaying it from the original audio signal.
Sony digital audio video control center STR-K750P (protection- what is that?) no sound
What is the device code for the Sony STR K750P? I'm tying to set up a universal remote control and need the 4 digit code.
The digital sound is off after 1 houre str de sony str de 485
It sounds like the receiver is either failing or going into a thermal protection mode.
There should be NO reason why the input source (digital versus analog) should make a difference unless you play the digital sources obscenely louder than the analog ones.
If you suspect heat, you should be able to feel it.
Can you verify that the digital sources ONLY do this?
SANSUI 218 - 250gb DVD Recorder Black & White
Send it back under warranty -- needs new main board.
Rudolf
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
