I am working on Paint Tool SAI, and the cursor jumps whenever I try to draw a new line. I think it's because the pen only loses control from the tablet when it's lifted more than 2 inches. This isn't good, because it always ends up jumping around or not moving enough unless I lift it up a full few inches.
SOURCE: Pen is always drawing
Dear All,
I have experienced the same problems in the aforementioned cases about the pen randomly highlighting things on the desktop/making selections, as well as loss of double tapping feature for double clicking. For my situation, I am pleased to say that I've managed to resolve the problem it may or may not help but worth a try. The solution:
(1) go to control panel and open up the 'Pen Tablet' icon,
(2) under 'Tracking' select 'Pen Mode' and click on 'Details' tab,
(3) under 'Screen Area' select 'Monitor' (*IMPORTANT*)
(* other settings I have are: 'unchecked' force proportions, 'Tablet Area' set to 'full', number of monitors under 'Screen Area' set to 1)
Following the above steps should remedy the problem. It worked for me. I hope it proves useful to you as well.
Kindest regards,
Jon
SOURCE: Pen keeps drawing when I lift it off tablet
This problem commonly occurs due to a stuck "nib" sensor (the sensor that detects pen pressure).
Take out the "nib" (important, so the sensor isn't damaged further) and whack the pen on your desk (or drop it on the floor
from 3 feet up). It re-seats the "nib" sensor when it's stuck. If this
doesn't work after multiple attempts, then the sensor may be too damaged.
SOURCE: Is it possible to remove features from a tablet?
I have the bamboo fun pen also. I am currently running Windows Vista 64bit home and have the same problem. I fixed mine by going into the control options > Tablet PC Settings > Other > Go to Pen and Input Devices > Settings (Under Pen Options) Then I clicked at the top Where it states "Enable press and hold for Right-clicking". I disabled that and my pen works with no holding for the right click. I can make scratch marks all day! Hope this helps you too.
SOURCE: cursor restricted to top left area using graphics tablet
It's the windows 7 tablet feature that causes the problem. To solve it you have to disable it. Go to start -> search write "services.msc" (without the strokes) and hit enter. Now search for "Tablet PC Input Service" double click on it and when a little window pops up set Disabled under startup type list box. Now if you want to see effect immediately there is a button Stop, click on it, and wait until service is stopped. When done close both windows. This way you don't have to even restart your pc.
SOURCE: Wacom Bamboo Fun Tablet-Mac. Yellow box pops up under pen cursor.
Your tablet is set under the handwriting setting. Go to system preferences and select ink under hardware. Then turn off handwriting recognition.
