Test Pattern does not show Magenta or Light Magenta.
WELL IT'S 5 DEC 2012, THIS HP 3210 QUIT MAGENTA'S.
WENT TO TOOLS TO CHECK LEVELS, NO YELLOW, GOT NEW CARTRIDGE, TEST SHOWED NO MAGENTA'S. REMOVED RIGHT SIDE COVER (GENTLY) AND REMOVED ALL TEN CABLES AND REINSERTED CAREFULLY. TESTED AGAIN, AND HAD LINES ONLY ON BOTH LIGHT AND DARK MAGENTA'S,
RAN CLEAN HEADS, SIX TIMES AND ALIGN PRINTER ONCE.
PICTURE GOT BETTER AND BETTER FINAL TEST DIAGNOSTIC PAGE PERFECT ALL SOLIDS. GOOD LUCK KEEP GOING
SOURCE: Error Message OXc05d2381 on HP Photosmart 3210
Reset the product:
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: HP C3100 photosmart printer - turn test pattern off
This should help:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01336397&cc=us&lc=en&dlc=en&product=1146331
SOURCE: I have a HP Photosmart C5180 printer.
If your color improved slightly when running the printhead option then doing more should help get better results. Sometime the printheads get really dirty/clogged and running the cleaning option more then once is needed.
If you get a slight line running across the page (from left to right) usually the indicates dust build up on the printhead or ink carriage. The dust acts as a paint brush being dragged across your paper as the carriage moves across the page during printing. You can clean the bottom of the carriage with a Q-tip or purchase some cleaning paper for your printer.
SOURCE: HP Photosmart 3210 Printer will not scan any
I had the same problem and this is what I did to fix it.
Go to control panel
choose printers
look to left and find scanners and cameras
click scanner
a pop up should direct you to scanning options and will lead your scanner to scan the item
hope this helps
SOURCE: My HP Photosmart 3210 won't print
Try this:
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "OK".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
