Xp installs without no problems and i ran the windows 7 compatibility wizard says its fine to run windows 7
SOURCE: installing of windows xp pro with caldera dos
Sounds like your not booting up to the CDROM that you XP PRO disk is in you booting to the hard drive .... what you need to do is go into your bios (usually this is the DEL key, maybe F2, or F10), you will need to look at the screen as it boots up to know for sure... it will say something like Press DEL to Enter Setup. Under the boot menu choose to boot to the CDROM first... it has you put the CDROM and Hard drives in a boot order... ofcourse make sure CDROM is first. Save the Bios usually by hitting the ESC key after making the needed changes and then it will ask you if you want to Save, ... yes you do want to SAVE Changes. Good Luck!!! I hope this works for you!!!
SOURCE: Install WinXP from USB in Toshiba NB100
Depending upon your CMOS you will get the option of going to CMOS setup by pressing a particular key. I don't know yours wether it is Del key or Alt plus F12 or something else just look closely for it on the first black startup screen. Once you are inside your CMOS setup just go to the Advanced chipset settings and select first boot device as your USB. Now your main worry is which USB you are connecting your pen drive to. So if in CMOS you get many USB options then select one of any and keep on changing till you get the line boot through usb or boot through external media. Also keep in mind boot through other devices shall be enabled. Now save the settings and exit. If you require any further assistance just ask for it.
Thankyou for using free utlity at fixya.
SOURCE: Ms office installation problem
Here are the steps in a concise presentation
1. Go to the System area of the Xbox Dashboard and select Network Settings.
2. Select Edit Settings.
3. Under Basic Settings, check to make sure the IP Settings is on Automatic.
4. Now go to Additional Settings, select Advanced Settings.
5. At the bottom of this screen you'll see a heading called Wired MAC Address.
SOURCE: I have recently purchased a new HDD (I now have 2
1. If you are just setting up your computer to have an a regular HDD and Backup HDD, i would think you should be able to set that up by booting onto your computer regularly, go to start, then into My Computer and right clicking on the HDD you want to set as Raid 1.
But if just want that other HDD for Space on your computer, all you had to do was plug it in and there you go... extra space.
Now if your installing windows 7 on the other drive i would find that pointless because you already have it on your first drive unless your putting 2 operating systems onto your computer.
Hope this helps.
Testimonial: "Please learn to read. I said RAID 0, not RAID 1..."
SOURCE: Windows 7 WinExec failed: return=216 error
The program itself could be having problems with Win7
