Question about SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive
Problem USB sdtnpnahem-008G protect write
I can not format, I can not copy the file, Usb protect write
4 Related Answers
Anonymous
  • 54 Answers
SOURCE: My SanDisk Cruzer 8 GB
http://files.extremeoverclocking.com/file.php?f=197
Download and install this HP flash drive formatting utility and use it to format the flash drive using the FAT32 file system and it should work afterwards. Good Luck!
Posted on Mar 01, 2011
Anonymous
  • 57 Answers
SOURCE: my cruzer usb is locked
There should be software that comes with it that allows you to change the type of drive it is. It may be in a mode that makes it like an MP3 player and will not allow you to write data to it. Here's the link to download the software driver for it. This should allow you to change the drive type
http://www.sandisk.com/sandisk-support/driver-download-wizard
If your's is U3 compatible here is a wikipedia link describing U3 and how to use it.
http://en.wikipedia.org/wiki/U3
Posted on Mar 08, 2011
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: USB Write Protection
Put the memory card into the SD adaptor and turn the white switch on the left of the card in the opposite direction.
See if that will work.
You may have to turn your phone off and back on again as well after reinserting the card back into the phone.
Posted on Nov 19, 2008
Anonymous
  • 18 Answers
SOURCE: 8gb micro sd card ,unable
plug the card into your computer with a usb adapter or if you have an sdcard slot use that. then right click on My computer or computer if your using windows 7. click manage, click on Disk Management, under storage. You should see your SD card there. Right click and choose FORMAT.
Posted on May 04, 2011
2answers
WHAT COULD CAUSE LG 32LJ570U NOT TO DETECT MOVIES IN A USB FLASH?
Some TVs only recognise digital information, (your movies), in certain formats. A format is the computer 'language' it is saved as. Get someone who is good with computers to check which format the movies are and which formats the TV actually accepts.
The movies could also be "Write Protected" which means the format, (language), the movie is written in has been altered to prevent copies being made.
Usb
try reformatting the flash drive .check and remove any partitions format to fat32
1helpful
Remove write protection trick
google "hp format tool", run as adminstator
I HAVE A FLASH Transcend (Jet Flash V15) 4GB I CAN NOT USE IT WHEN TRY TO COPY A FILE TO IT A MESSAGE APPEAR THAT THE DESK WRITE PROTECTED AND TRY TO REMOVE THE WRITE PROTECTION I TRY FORMAT BUT NOT WORK...
1.Close all files
2.Select Transcend Pen drive-Right Click-Format-ok.
3.After formatting you can copy all files upto 4GB.
Hopethis helps. If it does, please accept and rate the solution! Contact me withany more questions you may have. Thanks for using FixYa!
2answers
My SanDisk Cruzer 8 GB USB 2.0 Flash Drive SDCZ36-008G (new!)does not give in to formatting. Memory volume = 0, the flash drive does not open, but the operating system (Windows 7) considers that the...
Click on round windows button (on the bottom right) > right click on "computer" > manage > select disk management > if you can see the flash drive in on the right hand side right click on it > format.
About write protection
access it from a linux live cd, or winpe mini cd, where the file autorun.inf or a usb manager programe is not loaded, u can access the drive copy the files to your hard drive, format the usb, and its all done.
linux live cd: puppy linux
1helpful
Write protected usb
download puppy linux, burn it to cd, plug usb, boot cd, open gparted, select usb, format usb. done
if u need the files in the usb, u can mount your hard drive and your usb, and copy the files...(use the first icon on the desktop)
3helpful
I cannot copy files from computer to my phone memory card
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
4helpful
2answers
Windows was unable to complete the format
sir
u dont need to buy a new one. You can download file shredder from here . do following things :
  1. download and install file shredder
  2. shred all the files which are in pendrive(after shredding u will not be able to recover them)
  3. then try to format it .,
thankyou for using fixya
dont forget to rate the solution
have a nice day
2answers
I am having Jetflash v10 16 gb model 'Transcend' USB Flash Drive.
Dear Friend,
My Jetflash also writeprotected, there's no any solution for this in internet but I could solve this problem,
what you can do is, make your write protected drive "shared", that means go to my computer---> then rigtclick on flash drive---> click sharing & security---> check both "share this folder on network" & "allow users to change my files" ,apply setting then you'll be able to format your drive.
I could do it,
let others to know about this solution. Because I also suffered from this problem.
Amila--> +971559473812
[email protected]
SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive Logo
Top SanDisk Electronics - Others Experts
k24674
Ekse
Mehandi Husain ...
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
