How to install in windows 7
If you have the disk it should self install once you put the software disk in. If you don't have the disk go to hp.com and then click on support. There you will find a driver and download link and can download your software there. Depending on what antivirus you are using you may need to disable it in order to install the software.
SOURCE: Unable to install driver of HP deskjet 3740 on window 7
HP doesn't have the drivers available for windows 7 cause its only in Beta and they won't have it until windows 7 becomes official and available in stores. The only chance would be if you go into the control panel and then add printers. See if in there it has your make and model of your printer. If it doesn't then try a printer that is similar and it might install it. If you still can't get it to install then you'll have to wait for HP to come out with a driver for windows 7.
SOURCE: Recently I installed Windows 7 ,but i am not able
win 7 didn't found any suitable driver? if yes, than you don't need to install any driver, if not, than try vista drivers and run them in compatibility mod with vista - right click on setup, select properties and you'll find it
SOURCE: Have Windows 7 on my laptop. Have a HP Deskjet
simply download the new drivers from HP and install them , that will fix your problem
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
SOURCE: HP 6940 Deskjet driver not installing WINDOWS 7
hi,the reason why it most probaly comes with that error is that the driver is not meant for windows 7,so go on line check hp site, printer drivers and download.
