I don't believe any passenger car in the world,
monitors oil level,that is your responsibility
I believe it over heated and shut down
The are only two Fail Safes on your car I know of
I have a 2004 V8
One is ETC for ignition & throttle problems & the other
is overheating
They go into Failure Effects Management Mode
That is what you have. If it didn't shut off, you would have
seized up the motor or overheated it.
I would have a dealer or repair shop look at data first,
then once you have oil in it,you may be able to restart it,
after clearing the Fault Codes.
I would be interested in you giving me all the codes they get
SOURCE: oil level indicator fluctuates but has oil
it a common defect in the cluster it self another common problem is temp gage also 2 bars up 2 bars ..
SOURCE: 94 Lincoln TC engine stalls when slowing/stopping
Most common cause of stalling for Lincolns in that era is the TPS (Throttle Position Sensor). It regulates fuel mixture, idle speed etc. A bad TPS will usually act up in one of two ways:
As far as valve cover oil leak, it's a problem that should be addressed to keep oil from fouling your spark plugs but highly unlikely to be the cause of your stalling problem. Hope this answers your question. All the best.
Greg
SOURCE: crank no start
SOUNDS LIKE THE CRANK SENSOR POSS. AS I HAVE ONE HERE THAT I JUST DIAGNOSED FOR THE SAME THING WITH A SCAN TOOL WHEN WE FINALLY GOT IT NOT TO START. I'LL FOLLOW UP AFTER SENSOR INSTALL
SOURCE: 2000 Lincoln Town Car (Engine Service) found a EVAP System?
Check your gas cap. If someplace can test it you might luck out. This website advertises manuals and info online. The evaporator cannister is suppose to purify excess fuel vapors. But a system which is not sealed will code an error lamp.
SOURCE: 1994 Lincoln Continental Executive Series oil level indicator
There is a known issue with the connector for the instrument cluster
For your help, there are few Car Engine oil related solved problem
listed below. You can go through it.
High Oil Level on Dipstick
http://whatisbyme.blogspot.in/2012/06/high-oil-level-on-dipstick.html
Oil light came on and the car died?
http://schematicsdiagram.blogspot.in/2012/03/oil-light-came-on-and-car-died.html
How to replace Oil filler cap or breather cap?
http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-oil-filler-cap-or.html
Oil pouring out from left front of engine?
http://schematicsdiagram.blogspot.com/2012/01/oil-pouring-out-from-left-front-of.html
Common Causes of Car Oil Leaks?
http://schematicsdiagram.blogspot.com/2011/12/common-causes-of-car-oil-leaks.html
Troubleshoot Car Oil leak?
http://schematicsdiagram.blogspot.com/2011/12/troubleshoot-car-oil-leak.html
2004 Dodge Stratus: Windage Tray Problem
http://howtobyme.blogspot.in/2012/07/2004-dodge-stratus-windage-tray-problem.html
Toyota Highlander Sport Oil change details?
http://repairhelpcenter.blogspot.com/2012/01/toyota-highlander-sport-oil-change.html
Low
oil pressure light on Dodge Magnum?
http://howtobyme.blogspot.com/2011/11/low-oil-pressure-light-on-dodge-magnum.html
Kia Sportage leaking oil from oil pan?
http://howtobyme.blogspot.com/2011/11/kia-sportage-leaking-oil-from-oil-pan.html
Car Turns OFF
due to low oil pressure warning light?
http://schematicsdiagram.blogspot.com/2011/12/car-turns-off-due-to-low-oil-pressure.html
Toyota Corolla leaking oil from timing cover?
http://technoanswers.blogspot.in/2012/02/toyota-corolla-leaking-oil-from-timing.html
Overfilling oil in engine?
http://whatisbyme.blogspot.in/2012/06/overfilling-oil-in-engine.html
2000 Dodge Ram 3500 Cummins Diesel: Oil Leak
issues?
http://schematicsdiagram.blogspot.in/2012/06/2000-dodge-ram-3500-cummins-diesel-oil.html-----------
These will help.Thanks.
