Amp error and shuts off
SOURCE: i turn on my Pioneer VSX-D509S 5.1 surround amp
Disconnect all your speaker wires from the back of the receiver and turn it back on. If it shuts off, you need to have it serviced. If not post a comment and I can walk you thru troubleshooting. Hope this helps
SOURCE: PIONEER AMP ERROR
Most probably you have one of the power amplifier modules bad. They are the PAC010 and PAC011 type. You can remove one and power up the receiver. If it powers-up normaly it's that one.... (50% chance) Otherwise remove both and it should power up normally. Beware that these parts are expensive... Most times just with a new part the problem is solved. YMMV. Good luck
