When i start up computer, windows splash screen shows then a blue screen with the windows xp icon but goes no further. i can't get to the user log in page so i can't use system restore even after pressing F8 and safe mode command prompt and all the other commands, such as last known good configuration, etc. Is there any other way i can access system restore or the user log in screen please.
SOURCE: Hard Disk Problem
bad power supply from on and off so much change that out
are u on labtop tho then u may have to redo it may gotten bug run trendmicro.com see scan for bugs do windows upidate
SOURCE: unable to boot the computer
start the sys and press F8 KEY to go to safe mode.
then run chkdsk
SOURCE: windows xp home edition computer will not start
If the system cannot start on safe mode probably your operating system has gone bad, to check your hard disk you can go use your windows xp disk, to boot from it press f12 choose cd rom keep on tapping enter and dont mind the message that you need to press any key to boot from cd, and then when you are on the welcome to setup page press r for recovery console, once you are there try to type in chkdsk /p and after type in fixboot and press y, and restart your system, if that wont work then your hard drive is bad.
You need to borrow a XP cd so that you can repair your installation
SOURCE: Booting up Windows after a Power Outage
That power outage probably damage some sectors of your hard drive, or corrupted some files that Windows need to boot up.
You need to install the Windows installation CD, and press R after the Welcome Setup screen.
Once there, it will should you the available drives and partitions.
If you have a computer set up like most people, you need to press 1
Then Windows will ask for the Administrator's password.
If you have no password, just press Enter.
Once on the C:/ prompt type the following
CHKDSK /r
To perform a check disk, and repair any errors on the hard drive.
The process take some time, but at the end, Windows will start up.
Please don't forget to rate this answer if its helpul
If running XP
A log-on loop on your Windows XP computer is a difficult situation where the computer never completes its boot cycle, restarting intermittently ad nauseam.
This issue indicates a major problem with the boot functionality of your XP system.
Restore the computer to working order by utilizing the repair and restoration utility on your XP system disk.
Insert the XP disk into the computer.
Restart the computer.
Press any key when prompted to boot from the disk.
Press "Enter" at the first screen and "F8" at the license terms.
Highlight the drive containing XP and press "R," repairing the operating system boot files and removing the log-on loop.
or
Windows XP sometimes has a glitch when you are logging in to your user account in order to boot the operating system.
The glitch logs you in and then logs you off the account.
This problem is usually caused by one of the programs that load during the computer's start-up.
Fixing this issue is a matter of ensuring that whatever program is causing the problem doesn't start up as soon as you start your computer.
or
Power on the computer and allow it to get to the user logon page normally.
There is no need to start up the computer in "safe mode."
Click the user who is having the issue and type in the user's password if one is set up.
Press and hold the "shift" button on your computer keyboard as soon as you see the tool bar load up at the bottom of the screen but before any other program has a chance to do so.
This stops any "Startup" program from running and logging you off.
Right-click the "Start" button on the bottom left of your screen.
Select "Explore" from the menu that appears.
Double-click "Programs" from the list on the left side of the window that pops up.
Double-click "Startup."
Select all the files inside the "Startup" folder by dragging a box over them.
Right-click anywhere on the selected files.
Select "Delete" to delete those files.
Note that deleting the programs from the "Startup" folder does not delete them from your computer.
All this does is make it so that these programs no longer start as your computer is starting so that any error in the running of the programs doesn't interfere with logging in to your account.
Hope this helps
or
or
Hope this helps
