The blue screen shows up every time I turn the computer on.The first panel says to hit F1 to continue.Touching F1 brings up a panel to select Safe mode.I select Safe mode , and I get the a screen that has scrambled text , after about 30 seconds then the screen changes to the blue screen.A problem has been detected , and windows has shut down the computer.----------------------?
SOURCE: Black screen comes up "windows
You should opt Safe Mode:
If the boot is success full:
If no success then I think its time to re-install your windows.
Please post your feed-back.
Gud Luck
Iqbal
SOURCE: Blue Screen
Is this still under warranty? If not then you'll just need to buy another HDD (hard drive device) and connect that one where the old was. Re-install XP or Vista. Conact Gateway or go to the Gateway web site to see what was hardware was supported for your system.
HDD IDE/EIDE or SATA/SATA II
OS XP or Vista
After you find out the info just install the new HDD, and install the OS. I only recommend doing this since you can't even get into the Safe Mode. When everything is back up and running you can also re-attach the old drive to what is called Slave or CS (cable select) this is more automatic process. Then you'll be able to recover any data missing that you need that was on the older drive.
SOURCE: Blue Screen
You could try turning the computer off at the switch when this happens. Sometimes it is a very temporary problem. You would need to wait a few minutes then turn it back on and restart your computer.
SOURCE: Computer goes to blue error screen 0x000000FC
Hi!!!!!
try to open up the tower
check the ram of your computer
try unset it and clean
and put it back properly!!!
if it is happen again!!!!
and try re-installe your video card
and if it is happen again!!
try to diagnost or surface scan of your harddisk if it has a badsector
it it is happen again try to reformat your
your operating system if you know how
to format and buck up all the files that u need
and if it is happen again in again
try to replaced your
Ram must be on the same speed or borrow from your friends
or
the hardisk may be had a bad sector try to bowrrow from your friends
try it!!!!
good luck
SOURCE: After loading Window service pack 3 update, comes up blue screen
i think theres a spyware or u have to repair ur windows
