I've tried two new ink cartridges in a week with about 100 copies....same result: light copies from darker originals
Double click Control Panel.
Double click Printers and Faxes.
Right click your printer and select properties. Now on General tab select "Printing Preferences".
Now select the basics tab and click "Advanced features" found on the right of the page.
Here you will be able to adjust the amount of ink that is used to print a page. Side the bar to the right to increase/darken the print.
Now click OK, followed by Apply.
Take care!
damnor01
SOURCE: My Dell V505 printer won't
Turn the printer off.
Disconnect the AC power.
On your computer, click Start
Click Control Panel
Click Printers
Select the Dell Printer
Uninstall it
Restart your computer
Turn the printer on
Allow the computer to reinstall the device-device for the printer.
Print a test page.
SOURCE: hp officejet 4215 all in one printing very light black ink, new cartridge
you must change your printer settings to the default settings.
SOURCE: Won't print unless all ink cartridges have ink.
Try changing it in the properties section under device settings
or go to color management if you have it and change the setting to black only,.
SOURCE: brpther DCP 330c does not recognise new black ink cartridge
Usually there is more than one cartridge empty when you receive this kind of problem. Try opening the top cover and check if the display changes - it should change to specify one (or more) of the color cartridges as empty. That one(s) should be changed too.
SOURCE: hp psc 750 won't print with new color ink cartridge
To solve the
printing problem..
# Hold the cartridge upside down, with the
bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the
cartridge on the bottom (where the ink comes out). Wipe the printhead
horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure
the ink is flowing.
# Next, look inside the printer and locate the
carrier that holds ink cartridges. Caution: Make sure the cartridges are not
installed at this point.
1. Look for a shiny piece of metal underneath the
contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and
wipe along the bottom of the shiny metal piece. Note: You may need more than
one swab.
# Reinstall the cartridges, making sure you snap
them correctly into the printer.
Hope this help. Please
Rate My Response! Thanks!
What type of printer is it and ink jet or toner cartridge?
Lexmark printer 4428-001
Lexmark ink 28
