Have a Maytag MTW5900TW0 Top load washer. Heavy duty Cycle does not work properly, or will not come on. Sometimes it strains and causes lights in room to dim in unison with agitator, or will not come on at all in heavy duty cycle, but this is not consistent, and sometimes it does work. Other cycles operate normally with agitation, but heavy duty and normal cycles will get to rinse cycle and not drain, or finish rinse cycle and not activate spin cycle. Pump is pumping out water in certain cycles and works. gentle and hand wash cycles work thru all different cycles and finish washing loads. Is it the timer, or the agitation/electrical control module? This seems most likely. transmission not making any strage noises. have has a few instances where when starting normal was cycle, It agitated at heavy duty speed.
SOURCE: Maytag Washer Getting stuckon wash cycle
the possibility of it being the timer is most likely..as the rest of the cycles remain ok.. if you require a timer,you can get one here at this link..(click the link here) http://www.easyapplianceparts.com/AdvancedModelSearch.aspx?ModelNum=HAV4657EWW&mfgModelNum=&fkMfgID=1
please be aware that you will need the machine serial number in order for them to issue you with the correct part/s you will require.. parts are cross referenced with the serial number.
these diagrams will also enlarge in order for you to maintain your machine by yourself at little but the cost of the parts required... but please DO NOT ATTEMPT ANY REPAIR YOURSELF if you think you may not have the technical know how to follow these technical drawings..hope this helps
SOURCE: maytag washer will not agitate during wash cycle
http://appliancejunk.com/forums/index.php?topic=2946.0
Above is a service manual this will show you how to troubleshoot and repair.
