Question about Sony Playstation 3 (PS3) Console
My ps3 turns off a couple of seconds after it is turned on then the red power light blinks
It was working fine then shut off, since then when I turn it on it shuts its self back off with the power light blinking red
Posted by floyyd36 on
Race Supra
    New Friend:
    Problem Solver:
  • 10 Answers
If your PS3 console attempts to turn on, then beeps and a yellow light comes on and then your Sony PlayStation 3 shuts down or does not power on at all or shows no video means YLOD or Yellow Light Of death has occurred! A guy had same problem with His console 6 months back, He was able to fix it for 15 bucks ! without sending it to Sony for costly repair.
Posted on Jun 07, 2012
  • Jemayne Sol
    Jemayne Sol May 16, 2016
    what part is needed to fix this
5 Related Answers
MNfisherman
Nate Stansfield
  • 11896 Answers
SOURCE: 60gb ps3 wont start up.
Possibly the very common mother board failure. Slight possibility that the power supply is failed, but the capacitors in either component can be tested with capacitor tester and service manual to test for the faulty component.
Posted on Aug 27, 2009
Testimonial: "I found out that I got the YLOD ( Yellow Light Of Death) Thanks for answering"
localwonder
Michael Masters
  • 6784 Answers
SOURCE: my ps3 starts to turn on for 1 second. Yellow
HI, this is an emergency shut down, due to overheating. the yellow light is an indicator of a previous overheating issue that has damaged the power unit.
unplug the unit and, let it sit for 10 minutes to cool. after the cool off, plug the unit into the wall socket once more and, power up. if it continues to shut down and, flash the red light, this will confirm a major fault within the power unit. Contact Sony for the replacement of the power unit in this case.
***NOTE(If the unit begins to play normally after the cool-down period, you will need to purchase a cooling device to prevent future overheating issues).
Posted on Jul 21, 2009
issken
Will Hartford
  • 1472 Answers
SOURCE: My ps3 shut off secs after i turn it on red light blinks n beeps
Note I do PS3 repairs and in most cases when the PS3's that I have seen failed because the user did not keep the system in a good place. With the PS3 it only has one main vent and alot of people are letting it get blocked or sticking it in a spot that has little to no air flow causing the system to over heat. So keep this in mind when you get you replacement unit.
Issken
Posted on Aug 28, 2009
Testimonial: "yeah, i kept remindind my sis-inlaw to keep the glass door open.now i know how this happened.Thanks for the advice. great help"
shawn
  • 73 Answers
SOURCE: My playstation just shut off an the red light flashes
do you get a yellow light? i bet you do..
1)Turn off your playstation 3. If you think your ps3 has been caught by the heat, then wait at least 20 minutes and put it back on again
2) Check if there's any loose cable.
3) Try to put out your playstation's hard-drive, and put it back in. You might want to repeat this 2-3 times for better results.
If this did not work
Send your playstation back to Sony
Posted on May 10, 2010
Peter Fix
Peter Harrison
  • 187 Answers
SOURCE: PS3 won't turn on
hi there king
This is more an amber coloured light and in the gaming world its known as the YLOD the yellow light of death,
You can send the console to Sony to fix for around $150 4-6 weeks of waiting time.
The More popular choice at moment is to fix it your self at home using a PS3 repair guide made by a professional ps3 repair man for the complete beginner costing around $30 - $40.
You can see why its more popular and why gamers are turning to repair guides everyday.
Go to GAMER FIX and you will find a full description of your problem, also Sony's details if you wish to contact them and the most recommended ps3 repair guide on the web.
You will get back to gaming with either option
Best regards
Peter
Posted on Oct 13, 2011
While playing a game console turned off and game disc is stucked inside, turn power on and light turns green for couple seconds then flashes red and turns back off, no chance to eject game disc.
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly over heated. This may be caused by poor ventilation or the vents may be blocked.
The blinking red light is infact a general hardware failure message. In this particular case, his hardware failure is with the blu-ray drive, that's why the system does not shut down until the drive is accessed. if the system is overheating, it will tell you so in the top right hand corner. It will say the system has overheated and is shutting down to avoid further damage.
Provide a proper vent for the system...
Hope this will help...
May 28, 2010 | Sony Playstation 3 (PS3) Console
May 09, 2010 | Sony Playstation 3 (PS3) Console
My ps3 will not turn on. it tries but then the light just starts blinking red. it was working fine last night though
It sounds like a power cycle is needed. If you are using a power strip, please turn off the PS3 and then the strip. Count to 30. After 30 seconds turn the strip back on, followed by turning the PS3 on.
Hopefully that will solve your issue. Hope this helps and have a great day!
Feb 17, 2010 | Sony Playstation 3 (PS3) Console
My ps3 wont turn on
HI, the power supply is unstable or weak. you will need to replace this failing power supply soon. it is damaged.
Jun 16, 2009 | Sony Playstation 3 (PS3) Console
Beeps 3 times and blinking red light
do you have it conneting to the wall??? or threw something else???? be specific!!! it sounds like your power is not connected right!!! but explain to me in detail!!! check your connection from your ps3 or try cleaning the port from the connection!!
Dec 16, 2008 | Sony Playstation 3 (PS3) Console
PS3 won't turn on
hi there king
Best regards
Peter
Nov 08, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
236 people viewed this question
Top Sony Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
