Question about Sharp EL-733A Calculator
I have the sharp EL-733A, calculate the learning curve formula of y=ax(-b) on this type calculator
I have the sharp EL-733A, pls advise on how you calculate the learning curve formula of y=ax(-b) on this type calculator assuming the learning curve is 80% - how do you get the 'b' calculated then how do you complete the formula with the power of 'b'
Posted by shaunk258 on
5 Related Answers
Anonymous
  • 105 Answers
SOURCE: Sharp Scientific calculator EL-531D
you could try http://www.sharpusa.com/files/cal_man_EL531_509.pdf
this basically replaced the d model
or you could order one from:
http://www.andrewselectronics.com/
hope that helps.
Posted on Jan 26, 2008
Jerry
  • 207 Answers
SOURCE: I need to change the time on my Sharp EL-1750PIII calculator
You can access the .pdf manual for your particular calculator here:
http://www.sharpusa.com/files/cal_man_EL1750PIII.pdf
Page 1 for how to set date/time:
“RATE SET”: To set the date, time, and tax rate, set this switch at the “RATE SET” position.
Date:
• Enter in the order of month, day and year, then press to complete the entry.
• Use to separate month, day, and year.
• When is pressed, the number entered is evaluated and displayed as “date” if the
value is within the following range; “Error” is displayed otherwise, and the previously set
date is restored.
Month: 1 - 12; day: 1 - 31; Year: 2000 - 2099 (in 4 digits) or 00 - 99 (in 2 digits)
Time:
• Enter in the order of hour, minutes, then press to complete the entry.
(There is no entry available for the seconds value. The clock starts at zero second.)
• If the hour/minute digit is less than 10, it is not necessary to enter the first digit “0”.
• Use to separate hour and minute values.
• When is pressed, the number entered is evaluated and displayed as “time” if the
time is restored.
Hour: 0 - 23 (24-hour system for the hour entry), Minute: 0 - 59
Posted on Apr 27, 2009
Anonymous
  • 81 Answers
SOURCE: how to calculate
It's very simple: the calculators have a default base 10 so that log x it's log x base 10 so here is some logs:
log x base y = log x / log y
log (x*y) = log x + log y
log (x/y) = log x - log y
Hope it's helped
Posted on Jul 06, 2009
Anonymous
  • 1126 Answers
SOURCE: need a manual for the sharp EL-5103S calculator
http://www.sharpusa.com/products/support/view_all_models/0,2326,32,00.html
I don't see that model listed...are you positive on exact model number?
Posted on Sep 05, 2009
Anonymous
SOURCE: Sharp EL-1801V Calculator
Change the switch to Rate Set, then input the mm.dd.yyyy then the clock/time button then hrs (military time).minutes then clock/time button.
Posted on Feb 11, 2010
Cant find the Log function on the EL 733A
There is no common logarithm function on this calculator. However, you can calculate it easily enough using the natural logarithm function (ln). The log of x is equal to ln(x) / ln(10). In words, calculate the log of a number by calculating its ln then dividing by ln of ten.
Mar 02, 2011 | Sharp EL-733A Calculator
Where do I find the Log function on the EL 733A calculator
Log mentioned above is base 10. Hope this helps.
P.S. I posted an image, got a post error if typed on plain text, fixya won't accept.
Where can i find sharp el735 manual
GOTO http://support.sharp.net.au/
in the pickup menu .. choose alculator... and put in model EL-735
Ive just done that.
Aug 20, 2009 | Sharp EL-733A Calculator
How do I use sharp EL W531 to solve quadratic equations?
This calculator does not have a program to which you give the equation, and which returns the solutions. Sorry. You have to use the formulas you learned.
Let the equation be ax^2 +bx+c=0
You compute the discriminant Call it disc.
disc= (b^2-4*a*c)
1. If discriminant is larger than zero you have two solutions. Let us call them x1 and x2.
Then x1=(-b+square root of disc)/(2*a)
and x2= (-b-square root of disc)/(2*a)
2. If disc=0 , square root of disc =0 and x1=x2=-b/(2*a)
3. If disc is negative, there are no real solutions.
To find the solutions you replace a, b, and c by their numerical values, to calculate disc, its square root, and calculate X1 and X2.
Hope it helps.
Jun 26, 2009 | Sharp EL-531VB Calculator
How do I use sharp EL 531W to solve quadratic equations?
You compute the discriminant Callit disc.
disc= (b^2-4*a*c)
Hope it helps.
May 17, 2009 | Sharp EL-531VB Calculator
How to solve quadratic equation in SHARP EL-531WH
disc= (b^2-4*a*c)
Hope it helps.
May 05, 2009 | Sharp EL-531VB Calculator
Sharp EL-733A Calculator Logo
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
