SOURCE: Getting ERR: INVALID DIM when pressing the Graph button
If the message appears when you try to graph functions deactivate the
statistical plots. To do so:
Press [2nd][Y=] to access (STAT
PLOTs)
Select [4:PlotsOff] then [ENTER]
That should solve your
problem. Post a comment to this thread if you still have trouble
graphing.If the message appears in another context, it sure
would help knowing the context of the error.
SOURCE: I get the error message ERR: INVALID DIM with
If you are in the stat mode and entering points in list 1 and list 2, it could be that one list is longer than the other.
If you are just trying to graph from the y= screen, one of your plots is probably turned on. The easiest way to fix this is to press the 2nd button the the plus button, then 7 and then 1 and then 2. This will reset to factory settings.
SOURCE: ERR: INVALID DIM displayed on graphing calculator
The solution for the problem is simple. When you use the calculator to
create statistical graphs, it is configured to accommodate the specificities of the
problem. However that configuration remains set after you terminate the
problem. So when you try to use the calculator to do other problems it
uses the stored configuration parameters, which may be incompatible
with the new problem. In particular, list of paired-variables must have the same dimensions: There must be the same number of elements in each list.
To
make a long story short, you should make it a habit to reset the Ram
every time you want to do a new problem. If for reasons of you own you
do not want to reset the Ram, you can prevent this type of errors from
occurring. This is how you do it.
To reset the Ram press [2nd][+] (MEM) [7:Reset][1:All Ram][2:Reset]. Press [CLEAR] to erase the Ram Cleared message.
SOURCE: whenever i press the graph button on my ti-83plus
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Y=, Window, Zoom, and all the Yellow (2nd) ones at the top work as well, it's only when I try to get to the graph...
Fixed by resetting the RAM, thanks to Sada786.
