My notebook freeevents has windows 7 home premium , but it heated quickly and it blocked every process, i couldn't do anything except i turn it off. now it don't start normally. it appears this "reboot and select proper boot device or insert boot media in selected boot device and press a key" . Can i find all drivers for philips feevent 11NB5801 if i install win sp3?
I've read this problem due to new hardware interferences with desktop computers, all they had to do is change a few pins around on the harddrives.. since this is a laptop, and is quite difficult and dodgy to access the hardware, the only other suggestion is to reinstall windows with a recovery disk, or windows CD-ROM.
Hope this helps :)
SOURCE: computer beeping and saying reboot and select proper boot device
When you reboot, go to BIOS, restore factory BIOS settings. If that doesn't help, you'll need to reinstall your OS.
SOURCE: reboot and select proper boot device or insert
check 1st is there any memory card plugin or not if plug then remove and restart the system 2nd install operating system .. if same then repalce hdd.. thanks...
SOURCE: when I turn the computer
you need to insert the os disk and select the auto repair function to direct the boot manager to the correct path of your os
SOURCE: when I turn on it says Reboot and select proper
This problems would most likely be caused because of your boot order has
been changed in the BIOS settings. If you have a floppy drive as your
first boot device and your CD ROM as your first boot device, your
computer will try and find media on these devices to boot from, if you
don't have anything in the drive this will happen as it did"Reboot and
and press a key" this just means that your hard drive that has your
operation system installed is not your primary boot device, however it
should be. To change this you need to enter BIOS set up and find where
these settings are and change your boot order so that your hard drive
with your operating system is installed on is the first boot drive, as
for your second boot drive, its really your choice.
Boot and hold F2 to get to BIOS,next Go to Exit tab and choose Load Setup Defaults.Exit and Save.
rather doing a driver hunt which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions
they will automatically search for and find the correct driver
also at cnet
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name sound drivers
http://www.innovative-sol.com/drivermax/
free program, paid update available
hope it helps
