Cant get full screen picture on my Sky tv channel
Can only get small screen picture on my sky channel
Posted by EUNICE FLETCHER on
SD Tech
    Top Expert:
  • 14,553 Answers
The set or a box if used may be able to correct this--some programs are only in letterbox or 4x3 format.
Question: Does the set play a full screen version of a DVD?
Posted on Jun 08, 2012
5 Related Answers
chrispurs1
chris pursloe
  • 372 Answers
SOURCE: Tv wont switch to Sky when remote control is pressed
Hi.
On the sky box do the following.
Check scart to tv is in the correct socket marked TV.
Try pressing services
then system setup
then picture settings.
Then try switching scart control to on or off.
If this sorts it great. If it doesnt check scart lead has all pins wired & not only A few.
http://dysonmanuals.llc.nu
Chris..
Posted on Jan 20, 2008
chrispurs1
chris pursloe
  • 372 Answers
SOURCE: Unable to Tune TV to Sky + RF output
Hi.
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
3)
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
Chris.
Posted on Jan 31, 2008
Anonymous
SOURCE: technika tv lcd 19-907 tuning in to sky in bedroom.
Hi i had the same problem but i have sorted mine now. What i was doing wrong was i wasnt tuning in the analoge channels only the freeview digital ones. To do this you need to first turn your tv on. Then press the "source" button, this will bring up a little menu at the top left hand side. When this menu comes up press the "Programme +" button (the one that you use for changing channels near the volume button) press this until you get up to "TV", when T.V is highlighted just wait 3 secs and it will switch over. You will probably get a blue screen with a no signal message (you are now on analogue) when you get this blue screen press the "tune" button. It will automatically start tuning in all of your channels, at first they will be fuzzy but as it works they will become clearer. Your sky channel will also be tuned in. When mine tuned in it didnt tune them in on the right numbers though, bbc2 was on number 1 etc. If you ever need to use a playstation or something it goes into the scart connection at the side of the t.v and you need to press "source" and go up to "scart". To get back onto the digital channels just press "dtv/dvd".
hope i helped!
Posted on Jan 09, 2009
Anonymous
  • 27 Answers
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Posted on Apr 04, 2009
Anonymous
SOURCE: SKY REMOTE NOT WORKING WITH MY NEW LG 42LH3000
To use sky+ remote control with LG 42LH3000 you must have a rev ver8 remote controller.
The codes are stored in a database of the Sky remote. If the old codes don't work
you may need to buy the latest Sky remote. Otherwise it is a matter of waiting for the
new Sky remote which may have the updated codes.
Note: LG Support supplied the following for Rev.8: 0206, 1293, 1665, 1174, 1176, 1219, 1280, 0857, 0851.
Version 1: August 1998
Version 2: December 1999
Version 4: May 2001 (Sky+ introduced)
Version 6: March 2004
Version 8: January 2006 (includes all current Sky+HD remote controls)
Posted on Sep 02, 2009
Colour is not normal, sometimes the picture is too dark, football pitches bright green, peoples faces very orange.
that would be a failing tcon board on the back of the screen.you would need to replace this part but they are available on ebay the part number is on the tcon board. match the numbers a version number to get the matching board for the screen. tcon board is the board were the main wire cluster goes to the screen board this is the tcon board.
Jul 03, 2017 | Samsung LE37R72B 37 in. HD-Ready LCD...
Small screen box on screen
Look to see if that box has PIP--it may be engaged and if so a small picture in one of several places on the screen.
Nov 05, 2012 | Panasonic Viera TH-50PZ85U Plasma TV
Panasonic TX P50V10B Plasma TV
In order to get any of the Freesat channels, you need to connect a Satellite dish to your TV. If you have a Sky dish, you simply need to run an extra Cable from the LNB from the dish and connect to your socket on the back of your TV.
In order to get Freeview channels and Analogue channels, you need to connect a aerial to the back of the TV.
There is a menu option for the TV to start straight to the AV input (your Sky HD box). It is Menu > Setup > Other Settings > Power on Preference. Select 'AV' for your TV to start on Sky HD.
Also even if you have your TV to start on TV, when you turn on your Sky HD box, it should automatically switch to the Sky box.
Oct 28, 2009 | Panasonic Televison & Video
White line accross screen holds when picture goes up and down.
This can be caused by the contrast being set too high. Typically, for a Sky box the TV's contrast should be set to around 65.
If this does not help, then the LCD panel is probably at fault.
Apr 25, 2009 | Philips 32PF5531D 32 in. LCD Television
LG 42 inch Plasma Picture in Picture with SKY satellite service
PIP only works off two seperate signals, eg you cannot watch 2 sky channels at a time, you can watch sky tv and then your analogue channel using PIP or freeview, you can then swap which is to be viewed as a large picture and which is to be viewed as the smaller picture or half and half.
Sep 07, 2008 | LG MZ-42PZ14 42 in. Plasma Television
Tuning to pick up sky feed
Sounds like from discription the sky feed is set up for analog channel 6. With my TV-HVR-1600 card, there is an option in the wintv application when you click the menu button in the application that says channel suite. If you select this option, you should find and option for analog source. Select analog source in this screen and you should be able to manually add channel 6 in the box at the top of the analog souce screen. Also if you have the sky feed connected and you you click the scan button on this screen, it should detect automatically is the sky feed is on.
Aug 20, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Wharfedale tv
GO ONTO YOUR SKY SETTINGS AND ADJUST FOR 16,9 THAT SHOULD CURE YOUR PROBLEM
Feb 15, 2008 | Televison & Video
Lg lc55
i have lg 42" lc55 model and had the screen smashed any ideas if it can be replaced!!!!!!!!!!!1
Jan 11, 2008 | Televison & Video
Please help
keep pressing the button called ARC until you get standard...let me know if it worked
Oct 17, 2007 | Bush 5693D 24" TV
Polaroid FLU-2632
I had the same problem. It's caused by the picture setting on your Sky box. Go ibto Services, select Picture Settings and set the mode to PAL not RGB.
Jun 07, 2007 | Polaroid FLM-2632 Television
Televison & Video Logo
417 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
