I can remove the regular screws but not the ones preventing a screwdriver from going inside then.
ANTI-TAMPER SCREWS
If
your model has anti-tamper screws, you can remove them using using a
T20H Torx type or GTXH20-100 screwdriver. If the correct tool is not
available, there are several ways to remove the screws:
- Use a
hammer and a small punch or similar tool to knock out the middle post
of the screw, then use a standard T20 Torx bit to remove the screws.
(Use safety glasses).
- Insert a small
flat-bladed screwdriver
(such as a jeweler's type) into the slot between the post and the edge,
tap the screwdriver firmly with a hammer to loosen the screw, grip the
screwdriver with pliers, and remove the screw.
This
detailed photo shows how a small screwdriver fits into the screw head:
- Use a hacksaw or
Dremel tool to cut a slot in the head of the screw,
then use a flat-bladed screwdriver to remove the screws. (Use safety
glasses).
We're
happy to help you with free
advice and we'd appreciate your thoughtful rating of our answer.
