I have changed tv lamp,and ballast,but still having the same problem,my tv turn off after a minute or so
SOURCE: projection lamp timer reset
I called 1800 211 PANA and they walked me through resetting lamp.
press recall and Volume- till solid screen shows, then hit recall till you see codes on top left, then hold volume- and mute(same time) till all codes return to 000000000000, then hit exit. turn off tv and check to see if it works
SOURCE: E44W46LCD Lamp Timer Reset
To reset the lamp timer, hold the "enter" button on the tv and the "mute" button on the remote at the same time. Once the menu pops up, hit the right arrow on the remote and confirm the reset.
I would guess that's it's a little too late for this answer now, but for future reference... ;-)
SOURCE: Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
SOURCE: reset timer toshiba 62hm116
I do not think failing to reset the Lamp Timer would cause the Lamp not to light. You need to get into the Factory Menu while the picture is on in order reset the Timer. I believe you have a Ballast issue either because the Power Supply is not powering the Ballast or the Ballast not Powering the Lamp. In either case, the only way to know is to have a professional to check it out and give a estimate for repair.
I hope this helps,
Skyassoc
SOURCE: How do we reset the lamp timer?
Try holding down VOL - on the TV panel and then hold SPLIT or PIP on the remote for 5 seconds. A message should appear saying it is reset. I hope this helps.
