SOURCE: Describe your Nuova Simonelli Mac 2000 I Group
Either the brew solenoid is bad or the shower screen is blocked or the metering jet on the top of the head is clogged.
SOURCE: mac cup V commercial Nuova Simonelli will not ****
First check the reset thermostat on the right side of the boiler below the level probe, make sure there is water in the boiler before resetting.
SOURCE: My Nuova Simonelli Mac digit pushes steam out of the group
The metering jet on the top of the boiler is blocked.
SOURCE: I'm getting no crema from my Nuova Simonelli Mac
Pressure pump is not working or can not produce 9 bar pressure.
Or the coffee is less tha 7 gr.
Or the coffee is grinded too thick.
Please remebr to vote for this answer thanks
SOURCE: nuova simonelli vip over pressure problem
Could be lack of water in the boiler, could be a faulty pressure stat or vent valve. Check the level probe first, then the vent valve and then the pressure stat. You can also use the manual fill to make sure water is getting to the boiler.
