Question about HP Computers & Internet
Wireless Keyboard HP RK713A not typing correctly
After having our HP rk713a keyboard disconnected from the computer and then reconnected, it will not type correctly. When we push the g button it types rfg54. When we push the .del key on the 10 key, it types 93. Any idea why this is happening? We haven't found that any other keys are working.
Larry Ng
  • HP Master
  • 6,101 Answers
The keyboards all fail when the battery dies
just like flash light does.
replace it now, per the manuals instructions.
Posted on Jan 16, 2018
Dick Monti
    Dedicated:
    Visited the website for 20 consecutive days.
  • 344 Answers
Try going to Device Manager. Right click on the Keyboard and choose Properties. Click on Update Driver as it might find something (let it look online also). Reboot the computer. If that doesn't work, go to Device Manager, right click on the keyboard, choose Uninstall, and reboot the computer. When the computer starts up and sees the keyboard and loads a driver(s) for it, it might fix it. Good luck.
Posted on Jan 15, 2018
5 Related Answers
Anonymous
  • 51 Answers
SOURCE: Slow or none response time for HP Wireless Keyboard
You might want to check the batteries being wireless, also check the device conected to your tower that reads the keyboard, make sure its pushed in all the way or not being disturbed by any objects.
Posted on Apr 30, 2009
Anonymous
  • 91 Answers
SOURCE: keyboard sensitivity
One way to correct this is to uninstall the software for the keyboard, and reinstall it again..
Posted on May 19, 2009
Anonymous
  • 38 Answers
SOURCE: locked keyboard buttons
If the wrong characters appear when you are typing or you are trying to use a keyboard that is different than the one that came with the computer, use the following steps to synchronize Windows to the type of keyboard you have:
  1. Click Start c01311982.gif , and type region into the Start Search field.
  2. Select the Keyboards and Languages tab.
  3. Click Change Keyboards .
    A Text Services and Input Languages window opens.
    Figure 3: Change Keyboard button
  4. Click Add .
    Figure 4: Add button
  5. Select the keyboard(s) you want to use and click OK .
    Figure 5: Add input language: US Dvorak keyboard selected.
    The new keyboard is added to the list of available keyboards and a keyboard icon appears on the system tray, allowing you to switch between the keyboard that you want to use with the mouse.
    Figure 6: Keyboard tray icon
  6. From the Text Services and Input Languages window, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    Figure 7: Move up button
  7. Click OK . You can now use the new keyboard. If you find that the new keyboard works well and you do not want to use the other keyboard, repeat these steps and Remove the keyboard that you do not want from the General tab of the Text Services and Input Languages window.
Posted on Aug 03, 2009
Anonymous
  • 5 Answers
SOURCE: my logitech wireless keyboard won't type. i
go to logitech support, download setpoint software and follow instructions on setting secure connection. i just did it with mine and keyboard got fixed. your symptoms should be that the qwerty keys dont work but the multimedia, clock and function keys are working. the setpoint software will take care of that.
Posted on Jan 05, 2010
Anonymous
  • 542 Answers
SOURCE: Dynex Multimedia Keyboard not working
Check and install drivers for your multimedia keyboard which is came along with the Keyboard. Also check whether the USB drivers has been installed properly and check the status of the same.
Revert back for more assistance. Also give your valuabale feedback/rating on the same.
Posted on Feb 07, 2010
Does RK713A work on Mac?
should you might have to go there there web site and down load the driver for that item
2answers
My wireless keyboard (rk713a) is not responding. my system is hp touch screen iq526. i tried system restore but that did not help. (in the notification area the battery is okay
Hey friend,
Reboot your system and it will detect the keyboard and plese make sure the port is okey. To be sure about it unplug and plug agin the Keyboard.
1helpful
Re HP wireless Elite keyboard (RK713A): I am using it with a Sony notebook (Windows 7) - can the F9-F11 keys somehow remapped to something useful eg. open Outlook etc. ? (Registry?) Thanks!
Here's the Microsoft way - note that all Win7 keyboard shortcuts begin with CTRL-ALT-(your shortcut key here).
Note also that a desktop shortcut must already exist to which to be invoked by the keyboard shortcut.....
http://windows.microsoft.com/en-us/windows-vista/Create-keyboard-shortcuts-to-open-programs
The way the Internet community does it:
www.autohotkey.com - freeware - allows you to "package" a number of
keystrokes into a "keyboard macro" and invoke that macro thru
the use of a "hotkey." Keyboard macros can be as short as one
function key, but some Win7 function keys cannot be ove-written, such as F5
The keyboard completely stopped working. Unable to type at all...any suggestions? I have disconnected and reconnected the keyboard and restarted the computer.
Turn off the computer, disconnect and reconnect the keyboard, restart your computer. If that does not work, try a different keyboard. If that still does not work than try a usb keyboard instead of a ps/2 keyboard or vice-vers. Good luck and let me know how it goes.
My hp wireless keyboard and mouse doesnt work
Hi, these instructions will help you, and "everything that you do for the Keyboard; apply the same instruction to the Mouse." First, click on the "Start" button, in the ["Start Search Window], Type: keyboard; the "Keyboard" Properties window will open. You can (Test) to see exactly how your keyboard is responding. If you are still having the same problem, (check, the Keyboard Status). "Update the Drivers," by clicking on the "Properties" button. Now in the event that neither of these solutions solve the problem, which I hope you shouldn't have to do anymore; "Uninstall the Keyboard. To "Uninstall the "Keyboard," do the following: Shut-down (turn- off completely); disconnect all the Keyboard Devices that are connected to the Computer. Next, turn-on the Computer, and go back to the "Keyboard Properties," next, click on the "Change Settings" button, next click on the "Driver" button, and select the "Uninstall" button. Once that is finished, shut-down the Computer again. Now you want to "Reconnect" all the devices that were connected before, and "Turn-on" the Computer. "You will repeat exactly what you did from the start, this will "Re-install the Keyboard. "Restart the Computer again after all changes have been made; this will ensure the changes take effect properly. "Rating the solution will let me know if it worked; or you may need further assistance, thanks."
2answers
How do I unlock a wireless keyboard
On the keyboard you will find a lock sign key on the kayboed press that one.
1helpful
My logitech wireless mouse works but the wireless keyboard does not. When I try connecting the keyboard the mouse stops working. I can get the mouse working but can't get the keyboard working. The only key...
The keyboard is not recognized by your PC. By the way, do you have the software installer for your keyboard.? Run the installer in your PC, and try again
if it now recognize the keyboard.
Computers & Internet Logo
Top HP Computers & Internet Experts
Ekse
Michael Thomas
Michael Thomas
Mandeep  Singh
Mandeep Singh
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
