I have accidentally erased some channels and i can't figure out how to re program my TV. can someone help me?
On your Renco Cable Controller Remote Controller, Press on/off switch to off then press -/--/--- Button for about 12 times then press 2 to restore all UHF channels. Press off again then 0 for about 12 times then 2 to restore all VHF channels.
It doesnt work sir any other tip? 2 of our channels has been lock (LOc)
Are you using the same model? Is it Renco Cable Converter? I yes, this is the only way to reset it. I have used this method several times and it does not fail to work. From what country you from?
Are you using the same model? Is it Renco Cable Converter? If yes, this is the only way to reset it. I have used this method several times and it does not fail to work. From what country you from?
What will I press 12 times again? The off button?
Mine too. Need help for renco cable converter rem control. I lost the brochure its there maybe someone can share me the code. Tnx much!
SOURCE: User Manual for (Dynex) DX-LCDTV19
Go to the Dynex web site. Type your model number in the search box and follow the link to the user manual.
SOURCE: lost manual for new sylvania lc420ss8
http://www.sylvaniaconsumerelectronics.com/pdf/manual/LC420SS8.pdf
nice TV . heres the manual.
SOURCE: cant program directtv remote to sony tv
I'm not sure of your model number but those remotes use the NEC codes and the variants on the NEC codes. If that code set is not the databse, you may have to "learn" it on your particular remote.
Good luck
SOURCE: can't program remote control...
The code is 11602. BUT, with OPC on it works only until it gets dark. Then I have to place alu foil over the right side of the box to keep it working.
SOURCE: My Sharp Aquos TV has stopped responding to remote control(s)
Unplugging my TV for 15 seconds (longer actually - at least a minute) made the remote and the satellite TV remote both work again with the TV. Thanks for the tip!
