The wheel circumference of a 1988 Schwinn AirDyne exercise bike may vary depending on the specific model and tire size. To determine the wheel circumference for your bike computer, you'll need to measure it directly. Here's how you can do it:
Measure the Tire Diameter: Lift the front wheel of the bike off the ground so it's freely spinning. Use a tape measure to measure the diameter of the tire from one side to the other. Make sure you measure the actual tire, not the rim.
Calculate the Circumference: Once you have the diameter in millimeters, you can calculate the circumference using the formula: Circumference (mm) = ? (pi) x Diameter (mm).
You can approximate ? as 3.14 for simplicity.
Convert to Centimeters or Meters: To make it more compatible with most bike computers, you might want to convert the circumference from millimeters to centimeters or meters.
try this link out...5.00 cup
The answer is: The change of 1 kg - kilo ( kilogram ) unit in a granulated sugar measure equals = into 5.00 cup us ( US cup ) as per the equivalent measure and for the same granulated sugar type.
linear measure is a length measurement so if you have 14 inches ,that is linear measurement
if you have metric measure and you want to convert to inches,
14 " equals .355 meters or 335.0 millimeters
it is still linear measurement
A millimeter is a unit of length, the thousandth of a meter. The milliliter mL is the the thousandth part of a liter. You cannot convert one of these units to the other.
Hi, 147 cm is equal to 1470 mm Unit Convert for Windows Download the above utility. Convert is a free and easy to use unit conversion program that will
convert the most popular units of distance, temperature, volume, time,
speed, mass, power, density, pressure, energy and many others, including
the ability to create custom conversions!
Hope it helps! Good Luck! Thanks for using Fixya! CreativeTECH
You have got to try to remember (or learn) the prefixes used in physical units. Milli means 1/1000 or 10^-3. Kilo means 1000, or 10^3. To convert from mm to meters you have to divide by 1000 because a mm is a 1000 time smaller than a millimeter and 1 mm is 0.001 m or 10^-3 m. To go from 1 m to 1 kilometer you have to divide again by 1000. So 1 m=10^-3 km=1 km/1000 I leave it to you to figure out how to go from mm to km. It is not difficult and you have got to learn a bit by doing your homework. Use these two equalities 1 mm = 0.001 m 1 m = 0.001 km So 15.9 mm =
