Question about Apple iPhone Smartphone
HOW TO RESET IPHONE
FOR GOT PASSCODE
Posted by ddenkhoff on
Michael Lei
    Master:
  • Apple Master
  • 498 Answers
If you have synced your iPhone with iTunes before you forget your iPhone password, you can reset your iPhone by using iTunes without losing data. Through iTunes, you can restore your iPhone from the last backup and remove the passcode from your locked iPhone while retaining your data. If iTunes asks you to enter the passcode, try another computer. Otherwise, you have to follow the reset iPhone Passcode with Recovery Mode section below. The following steps will show you how to reset iPhone password with iTunes.
Step 1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted.
Step 2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it and follow prompts to choose the latest iTunes backup to restore your iPhone.
After the restoration process is complete, your passcode will be erased and all your data will be restored from your backup. You will now be able to access your iPhone without any passcode. And you can set your new password on iPhone.
For more methods, check: How to Reset Password on iPhone
Posted on Jun 25, 2019
2 Related Answers
Anonymous
SOURCE: How to Reset my Iphone 3g passcode
our son he was on the iphone 3G and he changed the passcode and he forgot what he preesed and how would i get my old passcode back?
Posted on Dec 25, 2010
abankiir
abankiir
SOURCE: how do i reset my passcode for my iphone 4s?
i forgot my ipod passcode
Posted on Dec 18, 2012
How to reset passcode
You can follow below steps to reset your passcode.
If you haven't synced your iPhone with iTunes before or if you haven't enabled your Find My iPhone on, you can take advantage of the third method. Resetting iPhone Password in Recovery Mode is not complicated. The steps below will show you how to do that.
Step 1. Disconnect all cables from your iPhone and turn it off.
Step 2. Press and hold the Home button and connect your device to iTunes. If your iPhone does not turn on, please turn it on manually.
Step 3. Continue holding the Home button until you see the Connect to iTunes screen. iTunes will remind you that it has detected your iPhone in recovery mode.
Step 4. Click OK. The Summary tab in iTunes appears. Click "Restore iPhone" and restore your iPhone.
Recovery Mode will erase all your data and passcode from your iPhone, resetting it to factory defaults. Thus, you'll have brand new iPhone without any personal data after you reset iPhone password with Recovery Mode. Therefore, please consider carefully whether you need to use this method to reset password on iPhone.
If you remember your current iPhone password and you just want to change into a new password, you can finish it with ease. Go to Setting > General > Touch ID > Passcode (iOS 9/8/7) or Passcode Lock (iOS 6), then enter the current password and tap Change Passcode. Then enter the new passcode. Now, you have reset your iPhone password.
If this doesn't work, check this guide. How to Reset Password on iPhone
Aug 17, 2016 | Apple Ipad I-pad
How do I remove a passcode from an IPhone 4s?
Do you mean the network passcode?If so, to remove the restriction, I suggest you can approach Wickedunlock.com and specify the country,locked network of the iPhone 4S.Based on the availability you can get their permanent remote unlock service and remove the network passcode.
Sep 29, 2014 | Apple iPhone 4S
How can you reset a forgotten password on the iphone a1203 phone
You can reset your password througn restoring the device. If you have synced your iPhone with iTunes before you forget your iPhone password, you can reset your iPhone by using iTunes without losing data. Through iTunes, you can restore your iPhone from the last backup and remove the passcode from your locked iPhone while retaining your data. If iTunes asks you to enter the passcode, try another computer. Otherwise, you have to follow the reset iPhone Passcode with Recovery Mode section below. The following steps will show you how to reset iPhone password with iTunes.
reset-iphone-password-with-itunes-noceaq0kid4ty03ndmq2d5rf-4-0.jpg If this method doesn't work, refer to this guide. How to Reset Password on iPhone
Jul 23, 2011 | Apple iPhone Smartphone
Passcode
You will have to restore your iPhone, this will reset your iPhone but will fix the passcode issue.
Jul 20, 2009 | Apple iPhone 3G
How to reset password on itouch
how can i reset my ipod touch when its disabled
Oct 12, 2008 | Apple iPod touch
Apple iPhone Smartphone Logo
87 people viewed this question
Top Apple Cell Phones Experts
Ekse
Marvin
Marvin
sandyp4ever
sandyp4ever
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
