Bad sound driver - Computers & Internet
  • 147 Answers
If you getting bad sound driver, its problem related to your sound driver. Check device manager that your system sound driver installed or not. If driver not installed, install it form your motherboard CD or download it form motherboard model official web site like Intel, gigabyte etc.
If driver installed already then uninstall them and reinstall again your sound driver will properly.
Thanks.
Posted on Jun 07, 2012
Infinity BU- 80 sub sounds over driven or blowen
from what im seeing in the picture, you have a house surround sound sub wolfer an there supposed to soumd deep an the crossover controls this there not ment for continues music an house an car speakers are different ohloms the lower the ohloms the deeper the bass
Jan 09, 2014 | Audio Players & Recorders
Bad sound driver
you might have to uninstall the sound driver restart your computer then reinstall it
if your computer came with a motherboard disk the sound drivers could be on it
click start control panel sounds and audio volume advanced speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or
click start control panel administrive tools computer management device manager sound video and game controllers could be a yellow question mark? right click to uninstall or re-install drivers
if you dont have a motherboard disk you will need to download the sound drivers
hope this helps
Jul 23, 2011 | Computers & Internet
In my pc no sound please suggest me
download sound drivers supported to your motherboard :)
search in www.google.com with your motherboad name
please rate :)
Mar 28, 2011 | Computers & Internet
No sound from tweeter bx5a
First of all, never connect the audio from your receiver directly to the tweeter. You can blow the tweeter instantly. The mid-bass driver can be damaged from a direct connection as well.
Since you get absolutely no sound from either driver, this seems to implicate the crossover. If the crossover has opened, no signal gets through, if it has opened early in the signal path.
But, it is also possible that a short exists, and that perhaps your amp cuts off the output having sensed a short. The short could be in the crossover or one of the drivers.
Here are some troubleshooting tips--
To prevent damage to your amp, turn it off while making or breaking any connections inside the speaker boxes.
Write down which wires get connected to which place on the drivers, so you can get them back where they belong.
With your amp turned off, connect the bad speaker to your amp. You've already verified that no sound is produced when both drivers are connected.
So, with your amp off, disconnect one wire from the tweeter in the bad box.
Briefly turn your amp on and listen for sound.
If you get sound, the tweeter is shorted.
If you get no sound, with the amp off, reconnect the tweeter in the bad box and disconnect one wire from the mid-bass driver.
Briefly turn the amp on and listen before turning the amp off.
If you get sound now, but not before, the mid-bass driver is shorted.
If you got no sound either way, check the DC resistance of the mid-bass driver (only, not the tweeter. Ohmmeters put out a small DC voltage to test resistance. That DC voltage might damage a tweeter, maybe. Don't risk it). Ohm the mid-bass driver while it is not connected to the crossover. If the driver is good, you should read some ohms--a little less than the stated impedance. An 8 ohm driver might read 6.5 ohms, for instance. If you get an open or a short (with the crossover disconnected from the mid-bass driver) you have a blown driver. Two actually, since neither the tweeter nor the mid-bass driver produced any sound in the previous tests.
If you can't get ahold of an ohmmeter, try this--
Open the good, working speaker and place the two side by side.
Connect your amp to the bad speaker box only.
With your amp turned off, disconnect the wires from the mid-bass driver in the bad box and connect them to the mid-bass driver in the good box. Disconnect one of the wires from the "good" mid-bass driver first, so you don't have two crossovers connected to it at the same time--even if only one of them will get powered on. It keeps the confusion down to a minimum when trying to isolate your problem. Oh, and disconnect one wire from the bad tweeter, in case it is shorted.
Turn the amp on and listen briefly before turning the amp off.
If you got sound, the "bad" crossover is fine, but the "bad" mid-bass driver is blown. And, since you got no sound in the previous tests, the "bad" tweeter is blown, as well.
If you got no sound, try it the other way around. Meaning--
With the amp off, disconnect the speaker wires coming from your amp from the bad speaker box and connect them to the good speaker box.
Your amp is now connected only to the good speaker box.
With the amp still off, connect the mid-bass wires from the good box to the mid-bass driver in the bad box. Remember to disconnect one of the "bad" crossover wires from its own driver first, so only one crossover is connected to the "bad" mid-midbass driver. Remember to disconnect one wire from the "good" and "bad" tweeters, so the only sound you hear--if any--is from the "bad" mid-bass driver, powered by the "good" crossover.
If this produces sound, but the previous attempts failed, you have a crossover problem.
If you still get no sound, something went wrong and you need to retest the good speaker by itself and back up a few steps and try again.
Assuming you got sound from the "good" crossover while it was driving your "bad" mid-bass, make sure no wires have come loose inside the "bad" box. Assuming you have sound connections at each end of each wire, you now need to desolder the electrolytic capacitors from the circuit board.
Make sure you mark them first, so you can put them back where they belong.
You can remove only one at a time, if that helps.
Use an ohmmeter to check some components.
The big red coil should read pretty close to a short, maybe one ohm.
The capacitors should read open or infinite resistance, although you might see a steadily increasing resistance while the capacitor charges up from the ohmmeter. If you read a steady low resistance on a capacitor after it has been removed from the circuit board, that capacitor is bad and must be replaced. The markings on the capacitor should give you some clues as to the proper replacement.
All things considered, I suspect that your problem is a shorted electrolytic capacitor. But, I gave you all I could think of so you can narrow it down and isolate the problem, whatever it might be.
I hope this helps.
Feb 23, 2011 | M-Audio BX5a Speaker
Sound-drivers are installed-no sound
Hello!
In your case, you have problem with some parts of your sound card.Try touch with hand some parts of sound card, maybe have some bad contacts, or bad line (+ or in some case - with motherboard).
Also can be bad chip from sound card.
Nov 05, 2009 | EliteGroup P4M800PRO-M Motherboard
Bad DirectSound driver. Error code:88780078
check the sound drivers in device manager. if it gives yellow sign then re-install sound drivers.
Nov 29, 2008 | Computers & Internet
Bad direct sound driver
hi you update your pc format xp ???what is your configuration ????????
if you format your pc you load sound driver plz see you my computer properties then hardware then device manager then you look yellow mark ......if sound driver is not load plz setup your driver...
or if your pc conect net hope some virus ....plz scan your pc..........
Oct 30, 2008 | Microsoft Windows XP Professional
M2N-MX sound
Try reinstalling the drivers, which can be found here.
Apr 06, 2008 | Creative Labs Sound Blaster Live! 5.1...
Error code: 88780078
Error code 88780078 Means bad sound card driver or bad direct sound driver.
You need to re-install your sound card drivers. If this does not work you will need to download and install directx from www.microsoft.com.
Also check this thread
http://www.opentechsupport.net/forums/archive/topic/24955-1.html
Regards
Feb 21, 2008 | Computers & Internet
Computers & Internet Logo
222 people viewed this question
Ekse
Marvin
Marvin
