The first thing you want to do is check the breaker outside by the electric meter, actually turn it off and turn it back on, Then if that doesn't work call a tech. Anything you buy these days only last about 3 years
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
SOURCE: how do I replace belt on kenmore dryer 66512?
under the lint screen on the top of the dryer there are 2 screws. remove these screws. aong the edge where the front of the top of the dryer meet the top of the front of the dryer there are 2 clips. press in the clips with a putty knife to raise the top. look inside you will see 2 screws that go into the front of the dryer. remove thoughs screws and the front will lean forward and lift off. there you will be able to put belt around the drum, tension pulley and motor pulley
SOURCE: How do I get inside this DLE5977
There are 3 screws across the back of the top. The lid then slides back and comes off. From there it gets alot more complicated because you end up taking the front off and the bracket behind that then you can lift out the drum.
SOURCE: removing front panel on kenmore dryer
I was able to fix my dryer on my own. the problem was, i was instructed to access an area that wasn't correct for the needed repair.
SOURCE: Dryer Top Hot / New Heating Element Smell
Any time you perform work inside a dryer, lint can get kicked around and settle on components. It is common to have a slight burning smell for a day or so. However, your dryer getting too hot to the touch concerns me. Improper air flow is the number one cause of dryer overheating problems. You may have cleaned the lint out of the interior of your dryer, but did you check the air blower and vent duct lines? In addition, was the heating elements actually bad? Or, did you assume it was bad, because your dryer wasn't drying properly? The following link can explain:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Pay particular attention to the paragraph that discusses proper ventilation. I would recommend you remove the vent hose from the back of the dryer and attempt to dry another load. If the dryer dries more efficiently and the top panel does not get scorching hot to the touch, then you have a vent clog somewhere EXTERNAL to the dryer. If the dryer air flow exiting the dryer is weak and the dryer still gets too hot to the touch, you have a clog INSIDE the dryer.
Follow these steps, first and see what you find. If you verify your ventilation is clear and not kinked or clogged anywhere, then you might assume you have a component malfunction. I would hope to try to save you from purchasing parts you may not need. I hope you find this information helpful. Let me know if you require additional assistance.
PS Make sure you are using semi-rigid (metal type) vent ducting. It is crush resistant, heat resistant, does not kink easily, and resists rodents. It is what most manufacturers recommend. If you haven't replaced the dryer vent in a while, this may be a good time.
SOURCE: My kenmore, Series 80, model 110-62852101 heats,
You are correct in thinking its the belt, that is the likely culprit, although it could be the motor, but usually the motor would give some warning before going out...humming, slowing, etc. In order to get the front panel off, you will have to first get the top off. (The top snaps over the front panel).
