Question about Ademco 1 Ademco 6150 6150pl3 6150pl2 Keypad Fixed English
The system randomly beeps
The system acts like it is armed and then like someone opening the door and the counting beeps start. The thing is, the system is not armed and no one opened anything. This even happens when the system is armed. There is a BAT message. We have replaced the battery on the 7845gsm and cannot find any batteries on the keypads or glass break. The beeping stops after entering code, but several hours later, starts again. Even when we do not enter the code, the system never sets the alarm.
Posted by Antonio Zambrano on
Jim Rus
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
If it is wireless, then one or more of the switches need a new battery. I suggest replace them all and mark the date inside the box. I assume that there is no yellow triangle showing on the alarm panel. Triangle is for no phone connection.
Posted on May 30, 2017
My honda odyssey ex 2008 the doors do not move on
Do a reset on the door system, by pulling the door fuse. I don't have location, possibly drivers side fuse box.
Sep 15, 2014 | 2008 Honda Odyssey
Pc1555rkz
Could you maybe look for a brand and model on the system? Either on the keypad or on the system box (metal panel somewhere in the house)?
Then maybe Google the brand and model, looking for a manual?
May 20, 2017 | DSC Home Security
The anti-theft alarm goes off everytime you open door regardless if it is locked or not
Interesting, seems alarm has been set-off before<now circuit is ON> and not been re-set back to neutral<re-set circuit to OFF> so when doors are closed, alarm memory retains previous set alarm memory <circuit set to ON>. It'ill go off again whenever door being opened, regardless it have been armed or left open as the memory circuit recognise it still as before alarm set-off<circuit is set ON>.
Solution, 1) Read your car owner's manual in the alarm section, read on how to re-set alarm to neutral if it has been set-off while armed [my experience is by turning the ignition key as if you are going to start the car engine but do not start engine then back to off position, do it 3 times as it will beep after 3rd run]. 2) On 4th run, start the engine, lock all doors then unlock it, 3) Turn off engine, get out from car, lock doors and arm alarm. 4) Dis-arm alarm, open doors and see if it still set-off alarm as before.
If all that doesnot work, go to your local dealer as alarm system has a system fault that can't be fixed without proper equipments.
Follow the instruction on how to accept and mark advise as giving you a core solution. Return a thumb up and praise response. Thank you.
Jan 05, 2011 | 2000 Honda Passport
Blue led stays on instead of blinking .
disarm system get inside the car turn key to ON position with door OPEN push the black valet button one time turn key off
now your out of Valet mode
or
open your door hit ARM then DISARM then ARM and that should also remove Valet mode if you don't know where the valet button is at.
May 14, 2010 | Viper Security and Remote Start System...
Husbands 2003 dodge ram, it beeps when sets the alarm system, however, upon jumping on truck messing with door handles, alarm does not go off, why
there are all different type of alarm set ups ur truck possible set up for voltage drop (open door light goes on )sets off alarm-- if truck has aftermarket sensitivity alarm and not going off will have to adjust the unit to make more sensitive
Oct 26, 2009 | 2004 Dodge Ram 1500
Beeping at random times through the day
You are getting trouble beeps, every time you press status you delay the alarms for 4 hours then they begin again and beep every minute. You need to run a sensor test to find out which sensor has a problem. Open the panel, enter your code and press the test button, it will begin scrolling through the sensors. Activate each sensor until it stops, if one doesnt work it will keep asking you to activaate it. You probably have a dead battery in a sensor.
Jun 23, 2009 | GE Security Simon 3 Wireless Home Security...
Reprogram keyless entry system
1991-94 Nissan Maxima key less entry reprogramming procedure:
1. Enter the *original code found under the dashboard.
(*the code begins with the letter F and has 7 digits)
2. Close the doors and lock all of the doors,
enter the 7 digit code ( make sure you have your key in hand).
3. Once the code is entered correctly you will hear a long beep ♪ ♫.
While the beep ♪ ♫ is sounding ... ENTER your NEW 4 digit code, (you will then hear random beeps ♪ ♫)
Do not touch anything until the beeping ♪ ♫ stops.
4. To open the doors, the front windows and the trunk,
type: S(Clear) and the New 4 digit code and the door will open automatically.
5. IF by any chance you forget your new code. Just enter the original one and start all over.
Oct 23, 2008 | 1994 Nissan Maxima
Washer
DDO is dispencer door open
the magnet needs to be put back into the dispencer door the machine thinks the door is open...
let me know
Aug 12, 2008 | Frigidaire ATF6000ES Front Load Washer
90 sec count down
You Can Turn off the panel beep under the cover that is what i did.
Apr 15, 2008 | GE Security Simon 3 Wireless Home Security...
My refrigerator starts beeping (randomly) when I open the door.
Recently I thought one of my kitchen appliances was beeping and it took an hour to discover that the real culprit was a dying battery in a nearby smoke alarm.
Jan 09, 2008 | GE Monogram ZISS480DRSS Stainless Steel
Ademco 1 Ademco 6150 6150pl3 6150pl2 Keypad Fixed English Logo
119 people viewed this question
Top Ademco Home Security Experts
Marvin
Marvin
Tom Chichester
Are you an Ademco Home Security Expert? Answer questions, earn points and help others
