Question about Apple MacBook Air
Three-finger swipe between desktops not working as expected.
I have 8 desktops on my mac. Very often, when I three-finger swipe from, say, desktop 1 to desktop 2, the screen goes to desktop 2 but then immediately jumps to, say, desktop 6. Why is it doing that and how can I fix it? FYI, it only recently started this behavior. It used to work as expected; desktop 1 to desktop 2 or desktop 5 to desktop 4. Thanks!
Posted by Jeff FIeld on
Kerry Hostetter
    Novelist:
  • 97 Answers
I'd try adjusting your setting in
Apple menu
System Preferences
Trackpad.
Not sure what key combination can affect those settings.
If that does not help try resetting the PRAM and or the SMC.
Resetting the PRAM may do the trick:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
you've tried rebooting, you've reset the PRAM, you've done it all, but your Mac is still behaving strangely. What next? In certain circumstances, resetting your Mac's System Management Controller (SMC) can be a solution. This is sometimes necessary to restore normal lower level system functionality to your Mac.
Here's how to reset the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Posted on Dec 31, 2014
2 Related Answers
Anonymous
  • 60 Answers
SOURCE: Using the trackpad with firefox
Mozilla has been working on getting this added into Firefox so that you may not have to employ any of the below solutions.
SideTrack is one possible solution, the only concern may be you are actually replacing Apple's own driver with theirs.
A less intrusive approach would be to use MultiClutch which is a standalone application that allows you to customize how the trackpad behaves with the applications of your own choosing.
Changing just one of Apple's default settings for the trackpad will allow you to right-click.
Apple has not release the application interface code to 3rd party developers, so companies like Mozilla are having to reverse engineer in order to figure out how to make their applications utilize these new features. It is Apple's way of trying to steer you towards only using their own applications.
Posted on Feb 03, 2009
Macs R We
Macs R We
  • 481 Answers
SOURCE: Ibook g4 Blue screen
Yes, this can be fixed without losing all your files, but the more you play with it the less chance there is.
If I had your machine in my shop, I would boot it while holding down command-V. This causes a raft of diagnostic information to fly by on the screen. At the end, I would hopefully see something in the sequence that I would recognize as abnormal, possibly an error message explaining that some part of the boot sequence failed. The problem here is that you have to have enough experience to recognize what is normal and what isn't, because there are a lot of error messages that happen every time and mean nothing. Having located the problem, I would boot into single-user mode and move whatever was failing out of the way so it would boot properly, then replace that portion once we had gotten the machine up.
Since the average user is unlikely to be able to use this approach, I would recommend reinstalling the system with "Archive and Install." This replaces the operating system, but NOT your user files. If you have upgraded your OS since the gray install discs (and you almost certainly have), I would run the installation from the newest OS DVD you have. Warning: you MAY lose third-party applications (Microsoft Office, games, etc.) which you will have to reinstall from their original discs.
Posted on Sep 19, 2009
Screen is stuck fully expanded on startup screen
Maybe you have turned on the Zoom settings from the Accessibility menu. To zoom out, Triple tap the screen with three fingers until the screen zooms out. To disable Zoom, go to Settings > General > Accessibility, look for Zoom then click to disable.
Tips for Zoom:
- To zoom in or out, triple tap the screen.
- To adjust the magnification of the screen, press and hold with three fingers, then scroll up and down to change.
- To navigate the screen, swipe using three fingers to left, right, up or down.
Hope it helps!
Cheers!
-Josh
/uploads/images/screen-stuck-fully-expanded-startup-35310085-5-1.jpg
Mar 27, 2015 | Apple iPhone 5c
Tip
Software Spotlight: MagicPrefs
When released in late 2009, Apple’s new Magic Mouse had incredible potential and clearly innovated the mouse, putting the first ever touch sensitive surface into the face of the mouse. The new mouse adds a few nifty features like scrolling with a flick of a finger but lacks features from the Mighty Mouse. For example, launching applications like Exposé right from a button on the mouse. The free OS X program called MagicPrefs gives the Magic Mouse limitless user-customized controls to everyday applications by a swipe of a finger. The software enables clicks, taps, swipes, and drag and pinch finger gestures to perform handy operations. MagicPrefs can open any applications, search with Spotlight, hide other programs, and even right-click for those PC users. MagicPrefs is a great little piece of software to help get the most out of the Magic Mouse. MagicPrefs can be downloaded here and is well worth the time to download and install.
on Jan 07, 2010 | Computers & Internet
Why can't I get onto my gmail account
Go to your settings in your phone, is your mobile service turned on, you can turn this on by swiping with your finger.
Oct 11, 2014 | Apple iMac Z0GF0005F Desktop
Since acquiring Apple Mac I notice on my BT Mail (my preferred choice) I seem unable to see mail that is older, I can only see mail to bottom of page, why is this please?
If you use a touch pad place the cursor over the list of emails and then place your two middle fingers in the middle of the touch pad, swipe up the touch pad. If you use the mouse do the same except you can use one or two fingers to swipe up.
Aug 06, 2014 | Apple iMac Computers & Internet
Mac screen moves with mouse
the new mouse is delicate and sensitive, both of which can be turned down in system preferences. the "gestures" on the mouse are such that the screen moves when you swipe your finger. Gestures can also be turned off in System Preferences under Mouse
Mar 16, 2014 | Apple iMac G4 Desktop
I just install 1.5 GB in my Powermac Quicksilver G4 and now it won't power on. What's wrong?
Make sure access door is closed and latched completely & try pulling power cable for 30 sec then reattach and try restart. If those don't work - contact macsales.com (excellent Apple/Mac folks)
Mar 15, 2011 | Apple Power Mac G4 Desktop
All things on my imac desktop is bigger by 2x
You may have
- Adjusted the screen resolution inadvertently (go to the System Preferences > Displays panel to fix this, adjust the screen resolution to a higher setting, i.e. toward the bottom of the list)
- Inadvertently used "screen zoom" by holding control and doing a scroll with the mouse trackball (or a 2-finger scroll with the mighty mouse). To fix this, try holding control and scrolling the mouse's scroll wheel down. (Or swiping downward with 2 fingers on the mighty mouse if you are using one of those)
- Accidentally adjusted the size of the icons in the finder. You can fix this by going to the finder (click the desktop) and hit command J (or just go to View > Show View Options). This will allow you to adjust the size of the icons on the desktop, or any other window.
Oct 14, 2010 | Apple iMac 24" Desktop
Fingerpad
Yes, its the same.
Also:
Tapping two fingers gives you a right-mouse button.
Three fingers lets you scroll in any direction
Four fingers to clear the screen or change desktops.
Jul 15, 2010 | Apple MacBook Mac Notebook
How to setup finger print sensor
When you start a machine with a Fingerprint reader for the first time, you will see the following screen when you reach the Desktop. This is the main console for configuring and managing the Fingerprint reader.
Here you can enroll your fingerprint, and adjust your Power-on security settings.
When you click on “Create new passport and enroll fingerprints” you will be prompted for your logon password.
Once you enter your password you will see the main enrollment screen.
You can select a fingerprint to enroll either by selecting the fingertip with your mouse, or by choosing from the drop down list. To enroll, either double-click the fingertip you wish to use, or press the Enroll button
On the left is an animated finger that demonstrates how to swipe. You must swipe your finger three times to enroll.
If your finger is not centered, you will be prompted to move it to the right or to the left. If it’s not able to read at all you will be prompted to try again.
When you swipe successfully, you will see the highlighted portion go to No. 2 for the finger printer to be swiped again.
Once you have swiped three times successfully, the three images merge into one and you are brought back to the main enrollment screen, where the enrolled finger is shown with a red dot.
  • You can enroll multiple fingers.
  • The Enroll button has changed to say Delete. This allows you to delete a fingerprint you have already enrolled. If you used the mouse to click on a fingertip that was not already enrolled, the button would change back to Enroll.
When you click Next you are brought to the Power-on Security screen.
This is also the second choice from the main Fingerprints enrollment screen. Here you can use a fingerprint to replace your Power-on passwords if you are using them.
If you are using Power-on passwords, then select the box at the top. When you click on the Add button, you will be shown a list of the fingers that you have enrolled, and can select which one(s) you want to enable to replace your Power-on passwords.
Once you select a choice from the box, the finger will show up in the list. The first time you restart your machine after this, you may be asked to swipe your fingerprint as well as enter any Power-on passwords you have set. After that you should only be asked for your fingerprint.
  • Predesktop Authentication
    • In addition to the process above, there is a setting in BIOS that must be enabled for a user to be prompted for their fingerprint instead of a Power-on password. The Default for this Setting is “Enabled”, so no change should be necessary. It is in the Security Section under Fingerprint. The setting is called “Predesktop Authentication” Again, the default is “Enabled”. If disabled, a user will not be able to use their fingerprint on Power-on.
  • Security Mode
    • This controls what password will allow a user access to the system if they are not able to gain access using their fingerprint. The default setting is “Normal”. This will allow the use of either a user Power on password, or a Supervisor password instead of a fingerprint.
      The alternative setting is High. This will allow only a Supervisor password to be entered instead of a fingerprint to gain access to the system.
Once you click Finish, you will be brought back to the main Fingerprints screen.
The Create new Passport and enroll fingerprints choice has gone. Replacing it are two new choices:
  • Edit passport and fingerprints
  • Delete passport and fingerprints.
If you choose Edit passport and fingerprints you will be prompted to swipe your finger to confirm your identity
You will then see the password screen. Click next to go to the main enrollment screen.
This is the same screen that appears when you have successfully enrolled a fingerprint.
Here again you can delete or enroll fingerprints
I trust this was helpful and thank you for contacting the experts.
Jan 18, 2010 | Lenovo ThinkPad X300 Notebook
Apple MacBook Air Logo
257 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Lee Hodgson
Lee Hodgson
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
