Question about Casio FX-82MS Scientific Calculator
How to convert the pol to rec and vice versa in the casio fx-82MS
Xplain brfly abot the rec plzzzzzzzz
Posted by venkatesan.v.k on
k24674
  • Casio Master
  • 8,091 Answers
Here is a screen capture from the manual.
how to convert the pol to rec and vice versa in th - 6_7_2012_9_45_53_am.png
Posted on Jun 07, 2012
5 Related Answers
  • 102366 Answers
SOURCE: I need instruction manual for casio calculator
You can download the manual from the manufacturer's web site at
http://support.casio.com/manualfile.php?rgn=1&cid=004001013
Posted on Nov 07, 2010
k24674
  • 8091 Answers
SOURCE: PLEASE HOW DO I CHANGE MY CASIO FX-82MS
Use the FIX display format and set the number of decimal digits to be displayed to be 2 o 3 or more depending on your needs. Instructions are on screen capture below. Hope it helps.
Posted on Oct 11, 2009
Anonymous
SOURCE: Convert to Binary in Casio fx-82ES
first press on mode the choose 4:BASE-N the write 3 press = then chose bin you will get it
Posted on Jun 13, 2009
k24674
  • 8091 Answers
SOURCE: how do i calculate permutation in fx-82ms casio
Find on the calculator the [nPr] key either (you may have to use the [2nd] or [2ndF] key) then
1. Enter the number that corresponds to n eg. 18
2. Press the [nPr] key
3. Enter the number that corresponds to r eg. 5
18[nPr]5 gives 1028160
If you calculate combinaitions use [nCr] key.
Hope it helps
Posted on Sep 06, 2009
Anonymous
SOURCE: how to write log base 2 in casio fx-82MS
With log a / log b = loga (b) formula
In casio for log2 8 = log8 / log 2 = 3
Posted on May 19, 2010
Could you please help me .. Is it possible to calculare irr with casio fx 82 ms? Thank you very much
Internal Rate of Return (IRR) Calculation Using Casio MS ...
? 2:32
https://www.youtube.com/watch?v=7Lvqp_E54Y0
Apr 13, 2015 - Uploaded by Nurul Amin
Internal Rate of Return (IRR) Calculation Using Casio MS Scientific Calculator ... +Nurul Amin i have a casio fx-82ms can ialso calculate IRR?
Discounting Basics on Casio fx-991ES and fx-82MS ...
? 7:24
https://www.youtube.com/watch?v=Xs7rq4JI3mg
Feb 14, 2014 - Uploaded by Sujoy Krishna Das
Discount calculations on Casio fx-991ES and fx-82MS calculators .... Internal Rate of Return (IRR) Calculation Using Casio MS Scientific ...
Jan 10, 2016 | Casio FX82MS Scientific Calculator
Problem with casio 991 es
In the COMP mode (press MODE 1 to get there), press
SHIFT [Pol] (-) . 1 7 SHIFT [,] (-) . 4 7 =
[Pol] is on the "+" key, [,] is on the ")" key.
Dec 04, 2012 | Casio FX991ES Scientific Calculator
I need to convert the rectngular form to polar form , so how can i do that ?
In Run screen, Press OPTN, Press F6> repeatedly until you see the ANGL TAB. Press F6> again (once or twice). You will see the TAB Pol( and Rec(
To convert from Rectangular coordinates to Polar press POL(, type in the x and y coordinates then EXE
Example: F1: Pol(1,1) gives (1.314213562, 45)
F2: Rec(square root (2), 45) gives (1,1)
Make sure the angle unit is set to the one you need (degree or radian).
Apr 19, 2012 | Casio Algebra FX 2.0 Calculator
Convert from polar to rectangular & vise versa using calculator with RCL&POL GIVE EXAMPLE JUST PROCEDURE THANKS 9
Examples #036 and #037 in the Appendix illustrate how to convert between polar and rectangular coordinates. If you need the appendix and/or the manual, you can download them from
http://support.casio.com/manualfile.php?rgn=1&cid=004001004
May 22, 2011 | Casio FX-115ES Scientific Calculator
I am a casio fx-82MS user. i would like to know how i can convert polar form to rectangular form in my calculator
Press [MODE] and select [1:COMP]
Press [SHIFT][MODE] and select [3:Deg]. You can also use rad if the angle you are given is in radians.
To start the conversion
Press [SHIFT][-] (Rec) screen displays Rec(
Key in the radius r , ex: 3 screen displays Rec(3
Press [SHIFT][)] (,) to enter comma separator Rec(3,
Key in the angle in degrees, ex: 57.3; screen displays Rec(3,57.3
Press ) to close parentheses; screen displays Rec(3, 57.3)
Press [=]
Screen displays
Rec(3, 57.3)
X=1.620720961
Y=2.524532346
X and Y are the values of the coordinates.
If angle is in radians, [SHIFT] [MODE][4:Rad] the command
Rec(3, Pi) gives X=-3, Y=0
I just realized that your question pertains to the FX82MS but is listed under the FX115ES (That is quite a difference) So my answer above does not concern you but I will leave it as is should anyone need the answer for the FX115ES.
Look at the enclosed screen capture for the FX82MS
Nov 13, 2010 | Casio FX-115ES Scientific Calculator
How to change polar form to rectangular form by calculator?
Use the Rec function (shift of the - key).
Rec(r,t) converts a polar value of magnitude r and angle t in the current angular mode. The real value is assigned to X and the imaginary value is assigned to Y.
Use the Pol function (shift of the + key) for the reverse.
It's on page E-37 of the manual. If you've misplaced your manual, you can download a new one from http://www.casio.com/support/manuals
May 28, 2010 | Casio FX-115ES Scientific Calculator
How can i enter a polar form number with angle to convert into a rect form
how can i enter a polar form number with angle to convert into a complex numbe(a+bi)
Apr 28, 2010 | Casio Algebra FX 2.0 Calculator
How do you use the pol and rec
To avoid errors make sure that the angle unit is THE ONE required by your problem. To verify or to change the angle unit press [SIFT][MODE] and select [3: Deg] for degrees, [4:Rad] for radians, or [5:Grad] for grads.
Convert from rectangular to polar
[SHIFT][+] (Pol) . Screen displays Pol(
You enter the X-coordinate, and the Y coordinate separated by a comma, then you close the parenthesis and press [=].
Exemple: Polar coordinate of the point (1,1)
Pol( 1, 1) gives
r=1.414213562 (square root of 2)
θ=45
Here is how you enter it
Press [SHIFT][MODE][2:LineIO]
[SHIFT][POL] 1 [SHIF] [,] 1 [)] [=]
The screen displays
Pol(1,1)
r= 1.414213562
θ= 45
Convert from polar to rectangular coordinates
Rec ( radius, angle) =
Exemple: Recatngular coordinates of (r=3, θ=60°)
[SHIFT][Rec] 3 [SHIFT][,] 60 [ ) ] [=]
The screen displays
Rec(3,60)
X= 1.5
Y= 2.598076211
Jan 19, 2010 | Casio FX-115ES Scientific Calculator
Can you show how to convert pola to rectangular o
Pol( 1, 1) gives
θ=45
The screen displays
Pol(1,1)
r= 1.414213562
θ= 45
The screen displays
Rec(3,60)
X= 1.5
Y= 2.598076211
Hope it helps.
Nov 14, 2009 | Casio FX-115ES Scientific Calculator
How to convert polar to rectangular form
Press [=]
Screen displays
Rec(3, 57.3)
X=1.620720961
Y=2.524532346
Hope it helps
Oct 18, 2009 | Casio FX-115ES Scientific Calculator
Casio FX-82MS Scientific Calculator Logo
3,301 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
