Question about Refrigerators
My samsung fridge/freezer is only 3 years old, just started making loud noise, then when the fridge is opened sounds like the fan making a loud noise that goes down and stops. Then not long after that will start to do that again everything is working fine and everything is being kept cool
Posted by Kerry McMaster on
RSole
    Master:
  • 697 Answers
Compressors usually make a thrumming/humming noise, so yes, this sounds like the fan. It could be something touching the fan blades, like ice or a wire. If you can unplug the fridge and remove panels near the fan, you may discover the problem.
Posted on Jun 06, 2012
1 Related Answer
alastair milne
  • 117 Answers
SOURCE: My samsung fridge/freezer is only
hello hope this helps , these guys realy help full with
samsung fridge freezer problems
Posted on Oct 09, 2010
Samsung refrigerator loud noise
if the fan is still running when you open the door , the I would be leaving that idea as a last resort
try this
get 2 taper door chocks and put one either side at the back of the fridge
push the cabinet sideways and slip one chock in a bit then do the other side
many noises are from the bottom plate that the compressor is mounted on from tapping on the floor and lifting it a bit stops the noise
the same as when you open the door the pressure on that plate is removed and so it stops hitting the floor
Nov 04, 2015 | Samsung RS261MDWP - 26 cu. ft. Side by...
My Samsung rs 2556 SH side-by-side fridge is making a loud whirring noise, but when I open the fridge the noise comes to a sputtering stop. It starts again a few seconds after being closed. Noise sounds...
there is a evaporator defrosting problem; ice building-up. the evap fan is mounted right on top of the evap coil. this will get progressively worse; and, the fan will get completely jammed with ice; and stop altogether. your fridge will get warm and the freezer will not cool properly. you should get it looked at asap..
May 18, 2010 | Samsung RS2630WW Side by Side Refrigerator
Fridge making loud noises occassionally
the noise can be from the fan next to the compressor or the fan in the freezer.
check them when you hear the noise if they tuch something or they might need to be replace b/c of berring problems...
Jan 06, 2010 | Refrigerators
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
I have a Samsung RS21DPSM side by side fridge under 2 years old and the other day a loud noise was coming from fridge Sounds like a fan as when you open fridge door it grinds to a stop) compartment and...
There is a design problem with this model. The fridge section is icing over due to a design defect and the noise you can hear is due to the fan on the motor driving against the ice. Eventually the motor will be stopped from running and the fuse will blow in your plug. Contact Samsung and they should replace the defective parts with a fix.
May 11, 2008 | Heating & Cooling
Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung side by side refridgerator making noise and freezing
its a heater cycle problem..the defroster is not working properly. its building up ice in the evaporator that touches the evaporator fan that makes that loud noise but stops when you open a door. it could be either a bad heater, a bad thermo disc or a bad timer.hope i was able to help
Feb 12, 2008 | Refrigerators
Refrigerators Logo
1,103 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
john h
