Upper arm does not work...all the water at the bootoms dissapears when the washer goes to use the upper arm and the pump makes a loud noice as if theres no water in the diswaher
SOURCE: Hi I have a Kenmore model
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming
the top spray arms are clear of debris, remove the lower spray arm to
access the wash motor. Remove the 4 torx screws and the filter
(accumulator assembly). Remove the torx screw and the inlet protector
that covers the chopper assembly. Make sure the chopper is not broken
(broken chopper will fill with debris and block water flow). While
holding the chopper blade, reach inside the "D" shaped opening on top
of the motor and spin the wheel/motor by hand in each direction to make
sure either the chopper gear or the motor gear that drives the chopper
is not broken. Replace the chopper if necessary (part # 8268383). If
the motor gear is broken, replace the sump and motor assembly (part #
8535150). Remove any debris from the sump area in the process.
You
don't have to because the door will be open, but if you feel more
comfortable shutting off the power to the dishwasher, do so.
SOURCE: Kenmore model 665 does not clean dishes
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
SOURCE: Kenmore (Whirlpool) 655 1589910 Dishwasher.
you need to clean/ check the chopper. sounds like you have a bad motor. about 2-300 dollars for the part
SOURCE: My Kenmore Ultra Wash II fills with water but doesn't spray.
i would suspect water mains problem, not enough water getting to the machine sometimes inlet get clogged with lime.adrian,,,,
