Original problem I had sound and no picture, intermittently the picture would come on and it would work until switched off, now when you power it on the blue light flashes 8 times and it powers itself off and goes into standby red light is on.
SOURCE: LG LCD TV Standby Light Flashing Red Continuously
I have had this same problem twice in the past 3 months. So far both times I've been able to get it back after a week or two. I'm not sure what works, but unplugging and detaching the antenna and cable and waiting a few days seems to be the key. In both instances, I unplugged it for a few days then plugged it in for a few days and repeated the processes until I eventually got the steady red led. Both times prior to the red led the led would flash red then green and make a clickiing noise for several hours before I was able to get it working again.
Posted on Apr 22, 2008
SOURCE: 42 LG plasma no picture but sound. found internal
Sounds like it started "Protection Mode" because of a failed electronic part inside the TV. When this happens, the TV will keep turning itself OFF or will not turn ON at all. This keeps the other parts inside from being damaged. Most likely the TV has a power supply related problem.
The common part to go bad for flat panel screens circuit board that powers the screen itself. Most manufactures call it a Backlight Inverter Board.
But, I can't say what is 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom.
You have a few choices:
1. Best thing to do, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, schematics, test points, and part# lists.Usually, cost under $20. Its the best repair guide material for fixing TVs. And most cases the new part cost less than $15 by searching on the internet with the part number.
2. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 21, 2009
SOURCE: LG 19 LH 2000 no picture or sound
i have exactly the same problem and my tv is just 2 weeks old !!
any soloutions?
Posted on Jan 22, 2010
SOURCE: No Sound, No Picture on LG 42LC7D
I do not have a solution but I have the same situation with my tv
Posted on May 25, 2010
May 08, 2015 | Audio Players & Recorders
Jan 01, 2014 | LG 42PQ3000 42" HDTV Plasma TV
Sep 22, 2013 | LG 42PQ3000 42" HDTV Plasma TV
May 29, 2011 | LG Televison & Video
Jan 17, 2010 | LG 42PQ30 42 in. Plasma TV
Nov 21, 2009 | LG 42LG50 42 in. LCD HDTV
Jun 11, 2009 | LG Original HBM-770 Bluetooth Headset
