Run HyperTerminal in Windows by going to Start > Programs >
Accessories > Communications > HyperTerminal.
After clicking on the HyperTerminal icon, you will see this window:
HyperTerminal prompts you to create a new connection. Note that this
is not required but let’s go ahead and do it.
Type in the word
cisco for the connection name and click OK.
Connect your Cisco device to your PC’s COM1 port but don’t turn it
on yet. On the next window that appears, make sure that the “Connect
Using” field says COM1 and click OK.
On the next window, change the Baud rate to 9600 and click OK.
Now, turn on your Cisco device. In the HyperTerminal window, you
should see the boot up process for your device, like this:
document.write('');
CollectiveMedia.createAndAttachAd("ns-74737014_1271195234","http://ad.doubleclick.net/adj/ns.petri/archive;net=ns;u=,ns-74737014_1271195234,11286e7f1d8af7d,ce_mobile_blackberry,;;kw=;tile=2;ord1=504214;sz=300x250,336x280;ppos=BTF;contx=ce_mobile_blackberry;btg=;ord=3760843785557546?","300","250,336",false);
You have successfully configured HyperTerminal and connected to your
Cisco device.
When you are done and try to close out HyperTerminal, you will be
asked if you want to save this connection. I suggest saving it with the
name you gave it,
cisco, so that you don’t have to configure it
again next time.
