Question about Rotary Lift (ROTSPOA10) Twin Post Lift SPOA10
Rotary lift will NOT lower...has a code of 10 beeps...it will raise up.
Posted by Evelyn Craig on
  • Evelyn Craig Jun 06, 2012
    I guess what my question is, is, what could be wrong with my rotary lift that it will not lower with the touch pad? It will raise with the touch pad....but will not lower. It gives a "10 beep" beep....I assume that is a code.
  • Anonymous Apr 09, 2017
    maybe there is something blocking it
twinkle
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 22 Answers
Can you refresh your question? What is your question exactly?
Performance Chip Tuning
Posted on Jun 06, 2012
How do you virtically raise the steering wheel in hino rainbow bus
talk with a service center as many vehicle only allow for an up/down ( tilt) position of the wheel
you may be requiring the wheel to move in or out closer to the driver
Dec 10, 2016 | Cars & Trucks
How to correctly put on the belt that raises and lowers blade on a 2004 Dixie Chopped 72in xt3200
I don't recall a belt that raises and lowers the blade. Normally you would have either an electric or mechanical deck lift that raises and lowers the whole deck
Jul 04, 2014 | Garden
How do I solve Error 42?
Precor Error Code 42 Error Code: 42 Manufacturer: Precor
Model: All Models
Error Description: Error 42, Lift Position Value Out of Range. Error 42 is displayed when the lift position reported by the lift position potentiometer is found to be outside its set limits.
If an Error 42 has occurred, it is important to know the physical position of the lift when the error occurred. It is possible the lift is physically out of range or jammed. In this case, the Error 42 is a secondary symptom and the issue should be approached as an Error 40. Possible Reason:
  1. Bad or intermittent connection in the lift motor controller.
  2. The lift motor requires calibration.
  3. The lift motor potentiometer is bad.
  4. The lower PCA to upper PCA cable is bad.
  5. The lower PCA is bad.
  6. The upper PCA is bad.
Recommended Action:
  1. Intermittent connections can be difficult to locate. If the Error 42 condition is intermittent, a connection issue is probably the cause. This is definitely true if the Error 42 occurred while the lift was within its normal physical range. Inspect the lift potentiometer connector and repair connection if necessary. If the intermittent connection cannot be found or corrected, replace the lift motor. A lift calibration number of 0 or 255 indicates an open or shorted potentiometer connection. This means the problem could be anywhere between the lift motor and the upper PCA. Typically it can be identified and tracked using an ohmmeter.
  2. Using the appropriate service manual for the unit being tested, refer to the lift calibration procedure. If the information in the service manual doesn't match the lift position/physical lift position of the unit, recalibrate the lift motor. [Something caused the lift motor to be out of calibration. Investigate for cause and correct. Simply recalibrating the lift motor will not solve the problem.]
  3. If the lift calibration number is not 0 or 255 and does not change when the lift motor turns, replace the lift motor.
  4. Check continuity of the interconnect cable or swap with a known good interconnect cable to verify if cable is bad.
  5. Swap the lower PCA with a known good lower PCA to verify if the lower PCA is bad.
  6. Swap the upper PCA with a know good upper PCA to verify if the upper PCA is bad.
Lift Position Value Out of Range Precor Error 42
May 29, 2014 | Precor EFX 5.17i Elliptical Cross-Trainer...
My 2032e2 scissor lift beeps when raised up 6 feet
sounds like the tilt alarm is sounding, on the top control box are there any flashing lights? does the beeps happen at regular intervals, ie beep..........beep...........beep...........??
Jul 05, 2013 | Cars & Trucks
How to unfold a safety first playpen
Most all of the newer playpens called Pack N Plays use a bottom-center
safety device. You must lift up the bottom of the playpen, usually a tab or twist handle. Either lift or twist and lift to be able to drop or raise the sides. YOU CANNOT RAISE OR LOWER THE SIDES UNLESS YOU LIFT THE SAFETY UP. Dont man-handle the sides. Slamming them up or down will break them. Sometimes it helps to lift the side releases before pressing the releases thet are inside the cloth. Basically the floor of the playpen has to be sticking up to allow the sides to raise or lower and lock.
Feb 12, 2012 | Baby Gear
Oil pan repl. 1995 ford ranger 3 liter automatic
Oil Pan, Ranger SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Engine Lifting Sling 014-00036
Removal
  1. Disconnect battery ground cable. For additional information, refer to Section 14-01.
  1. Remove air cleaner outlet tube assembly by unclipping air cleaner clamp, loosening hose clamp at outlet tube, disconnecting intake air temperature (IAT) sensor and mass air flow (MAF) sensor connectors, and crankcase ventilation hose.
  1. Remove oil level indicator fan shroud retaining bolts. Position shroud over fan blade.
  1. Remove radiator support bolts. Raise and secure radiator to front core support.
  1. Remove engine mount nuts from studs.
  1. Unclip 42-pin connector from bracket and position it aside.
  1. Install suitable lifting brackets to left and right exhaust manifolds. Attach Rotunda Engine Lifting Sling 014-00036 (or equivalent) to lifting brackets. With a suitable lifting device raise engine approximately 50.8 mm (2 in). Install wood blocks between engine mounts and support brackets. Remove lifting device.
  1. Raise vehicle on hoist. For additional information, refer to Section 00-02.
  1. Drain the oil.
  1. Remove transmission insulator retaining nuts and install a jack stand to extension housing. Raise transmission about 25.4-101.6mm (1-4 in) to gain access for removal of oil pan.
  1. Remove transmission inspection cover.
  1. Remove starter motor splash shield.
  1. Remove starter motor retaining bolts and secure starter aside.
  1. If equipped, disconnect and remove low oil level sensor.
  1. NOTE: Oil pan fits tightly between transmission spacer plate and oil pump pickup tube. Use care when removing pan to avoid damaging either part.
    Remove oil pan bolts and lower pan.
  1. Remove oil pump retaining bolts. Lower and twist pump to allow the oil pan to lower completely. Remove the pump and pan assembly from vehicle.
  1. Remove and discard oil pan gasket.
  1. Clean the oil pan mating surface.
Installation
  1. NOTE: When using silicone rubber sealer, assembly should occur within 15 minutes after sealer application. After this time, the sealer may start to set up, and its sealing effectiveness could be reduced.
    Apply a 4.0-6.0 mm (1/5 inch) bead of Silicone Rubber D6AZ-19562-AA or -BA (or equivalent meeting Ford specifications ESB-M4G92-A and ESE-M4G195-A) to junction of rear main bearing cap and cylinder block and to junction of front cover assembly and cylinder block. Position oil pan gasket to cylinder block and secure it with Gasket and Trim Adhesive D7AZ-19B508-B (or equivalent meeting Ford specifications ESR-M11P17-A and ESE-M2G52-A).
  1. Install oil pump assembly and bolt. Tighten bolt to 40-55 Nm (30-40 lb-ft).
  1. NOTE: If oil pan is replaced with a new pan you must tighten new pan to spec then loosen and retighten.
    Position oil pan to cylinder block and install oil pan to engine bolts. Tighten bolts to 10-14 Nm (7-10 lb-ft).
  1. Remove jack stand and install transmission insulator retaining nuts. Tighten nuts to 85-118 Nm (63-87 lb-ft).
  1. NOTE: When replacing low oil level sensor, use a new metal gasket with a rubber O-ring.
    Install low oil level sensor. Tighten sensor to 20-34 Nm (15-25 lb-ft).
  1. Install transmission inspection cover and retaining bolts. Tighten bolts to 10-14 Nm (7-10 lb-ft).
  1. Install starter motor and bolts. Tighten bolts to 22-28 Nm (17-20 lb-ft).
  1. Securely install starter motor splash shield.
  1. Lower vehicle.
  1. Install lifting device and support engine. Remove wood blocks and lower engine back into original position. Remove lifting device and Rotunda Engine Lifting Sling 014-00036 (or equivalent). Remove lifting brackets from right and left exhaust manifolds.
  1. Remove support straps, lower radiator into position, and install radiator bolts to core support. Position fan shroud and install the retaining bolts. Tighten bolts to 6-8 Nm (52-71 lb-in).
  1. Install engine mount nuts and tighten to 98-132 Nm (72-97 lb-ft).
  1. Connect 42-pin connector to the bracket and install oil level indicator.
  1. Install engine air cleaner outlet tube assembly. Connect IAT sensor, MAF sensor, and crankcase ventilation hose. Securely tighten the hose clamp.
  1. NOTE: When battery has been disconnected and reconnected, some abnormal drive symptoms can occur while powertrain control module (PCM) (12A650) relearns its adaptive strategy. Vehicle may need to be driven 16 km (10 miles) or more to relearn strategy.
    Connect battery ground cable.
  1. Fill crankcase with correct viscosity and amount of engine oil.
  1. Start engine and check for oil leaks.
    Oil Pan Installation - Ranger
    Hope this helps
Aug 14, 2011 | 1995 Ford Ranger Supercab
I have a champion lawn mower PDCELM1034F or IT2000509PO10 or SKU 95589 these are all the code numbers on it not sure which one to give you, hopw do i raise the level of the blades so it dosent cut the...
I couldn't find this specific model, but here's a universal answer. On rotary mowers that you walk-behind, you raise the cutting height by moving the wheels down. Some mowers have a lever by each wheel for this. On others you must remove the wheels then put them back using different mounting holes. Ride-on mowers have a single lever which raises or lowers the entire mowing deck. I hope this is helpful. Al K
May 18, 2010 | Garden
Replacing a water pump on a ford windstar how do i do it?
Removal
1. Disconnect the battery ground cable.
2. Drain the cooling system. For additional information.
3. Remove the accessory drive belt.
4. Raise and support the vehicle.
5. Disconnect lower radiator hose from the water pump lower tube.
6. Remove the engine mount nuts.
Lower the vehicle.
7. Remove the cowl extension panel. (Thats theone with the wiper arms go through).
8. Disconnect the water bypass hose and the heater hose from the water pump outlet tube.
9. Remove the water pump outlet tube bolt and position the tube assembly out of the way.
10. Install the lifting eye to the exhaust manifold.
11. Attach engine lifting equipment and raise the engine 127 mm (5 inches).
12. Remove the bolt and the accessory belt idler pulley.
13. Remove the bolts and the generator support bracket.
14. Remove the four bolts and the water pump pulley.
15. Remove the water pump. Remove the five nuts. Remove the five studs.
Remove the four bolts. Remove the water pump, lower tube and gasket as an assembly.
Feb 22, 2010 | 2002 Ford Windstar Cargo
Is it difficult to replace the combination light switch
It all depends on the tools you have and if you have patience....this is the task for removing and replacing the switch:
Removal & Installataion
CAUTION These models covered are equipped with a Supplemental Restraint System (SRS), which uses an air bag. Whenever working near any of the SRS components, such as the impact sensors, the air bag module, steering column and instrument panel, disable the SRS and refer to the precautions in the Chassis Electrical Section.
  1. Make sure the steering wheel is in the center position (wheels in the straight ahead position)
  2. Remove the key from the ignition.
  3. Disconnect the negative battery cable first, then the positive cable.
  4. Wait 10-20 minutes for the back-up power to discharge. Do NOT proceed until the back-up power is discharged from the SRS system!
  5. Remove the driver’s side air bag module and steering wheel, as outlined under the Steering Wheel Removal & Installation procedure in this section.
  6. Remove the steering column nacelle, as follows:
    • Open the fascia lower access panel.
    • Remove 3 screws securing steering column nacelle halves together.
    • Release clips securing nacelle together and remove from steering column.
Exploded view of the steering column nacelle (cover) mounting
Remove the rotary coupler, as follows:
  • Release rotary coupler connector from bracket and disconnect from harness.
  • Disconnect rotary coupler connector from harness.
  • Remove rotary coupler.
View of the rotary coupler
  1. Release passive coil from steering column lock and lower the coil without disconnecting the harness.
  2. Release front wiper delay connector from column switch mounting bracket and disconnect from harness.
  3. Disconnect harness connector from wiper switch.
  4. Remove 2 screws securing switch, carefully raise edge of switch bracket to clear location peg and remove switch.
Release front wiper delay connector (3) from column switch mounting bracket and disconnect from harness. Disconnect the wiper switch connector (4), then remove the switch mounting screws (5)
To install:
  1. Install the new switch to bracket and secure with screws.
  2. Connect harness connector to switch.
  3. Connect front wiper delay connector and Install the connector to switch bracket.
  4. Install the passive coil to column lock.
  5. Install the rotary coupler, as follows:
    • Install the rotary coupler to steering column and connect connector to harness.
    • Connect rotary coupler connector to harness and secure to bracket.
  6. Install the steering column nacelle, as follows:
    • Position the nacelle to steering column and secure with clips and screws.
    • Close fascia lower access panel.
  7. Install the steering wheel and driver’s air bag module, as outlined in this section.
  8. Connect the positive, then the negative battery cables.
Oct 13, 2009 | 2001 Land Rover Discovery Series II
Rotary Lift (ROTSPOA10)  Twin Post Lift  SPOA10 Logo
325 people viewed this question
Top Rotary Tools & Hardware - Others Experts
Marvin
Marvin
rwkemper
Level 1 Expert
john h
Are you a Rotary Tool and Hardware - Other Expert? Answer questions, earn points and help others
