Question about Electrolux EL8602A Nimble Upright Bagless Vacuum Cleaner
My electrolux Nimbles roller is not working.
The roller/beater is not working, but I still have suction. It is still under warranty.
Posted by Robert Coffman on
Glen Coleman
  • 80 Answers
A common problem with roller/beaters is hair caught in the bearings on the ends of the roller. The roller is removable and requires regular cleaning or the belt will be destroyed.
Posted on Jun 09, 2012
After removing six screws, how do I get case apart to repair electric cord
How do i replace the power cord on electrolux nimble - Fixya
www.fixya.com/.../t25091002-replace_power_cord_electrolux_nimble
Sep 11, 2014 - Power cord is frayed next to body, need to replace it. how do i get ....See all Electrolux EL8602A Nimble Upright Bagless Vacuum Questions.
Amazon.com: Customer Reviews: Electrolux Nimble Upright ...
www.amazon.com/...EL8602A/.../B004GUFWBM
Amazon.com, Inc.Electrolux Nimble Upright Bagless Vacuum, EL8602A ... The rotating brush on/off buttons are located right under the soft-touch power button high up at .... Cord is a $30replacement part, which I'm regretting not doing from the get-go, due to ...
Apr 13, 2015 | Electrolux EL8602A Nimble Upright Bagless...
Beater bar on electrolux el8602
Usually you have to replace the belt or if it is burning up belt take beater bar out and check the ends to see if they turn. Sometimes they get thread up in them from carpet and get stuck from turning and then they will burn belt up. Rich
Dec 21, 2014 | Electrolux El8502a Versatility Bagless...
The hand held unit of my ergorapido works, however when in the stick the unit will not work, it seems to fire up then stops
check under neath to see if the bel is connected or it broke if its not sucking im not really sure how to answer that ive never had that happend it can be a wiring issue or switch it sounds like it can be the switch might need replacing the power or the pedal that unlocks it from the stick mode might be pinching somthing that stops it
Dec 05, 2014 | Electrolux EL1022A Ergorapido 2-in-1 Stick...
How do you get the rollers out oy the electrolux nimbke
This is very easy, all you need to do is remove two quarter turn locks on the bottom plate and then you remove the plate and can assess the Electrolux Nimble Brush Roller 16136 1
Aug 23, 2014 | Electrolux EL8602A Nimble Upright Bagless...
Electrolux lux legacy
open up the unit, locate the cord reel, manually retract it to tighten the clock spring. should work again. lookout for broken plastics
Sep 25, 2013 | Electrolux Band Aerus Lux Legacy Canister...
Electrolux el 500az turns itself off
Did you ever get this resolved? Mine was doing the same thing and I had the main board and accessory board replaced. It seems better but still shuts down every so often.
Mar 03, 2013 | Electrolux el500az air purifier
Electrolux EL8602A Nimble Upright Bagless Vacuum Cleaner Logo
897 people viewed this question
Top Electrolux Air Purifiers Experts
ray gallant
Tom Chichester
Marvin
Marvin
Are you an Electrolux Air Purifier Expert? Answer questions, earn points and help others
