The radio works fine on fm but wont pick up am stations any one know please
SOURCE: While my FM setting works perfectly, I can't pick up any stations in MW or LW. Any Advice?
Check with an Audi Dealer. There are some stations that went Digital along with the TV stations. Your receiver may be outdated.
SOURCE: 2000 Audi A6 Quattro Concert Radio
what do push on the radio to get the code to come up so i can enter my code in
SOURCE: radio stations cant be picked up on audi concert
Hi.
Check the antenna connector and wiring. The point where antenna loses connection is usually the coax connector at the back of the radio.
To pull out the radio follow the instructions in the video below:
See also: Removing and installing "chorus" and "concert" radios
Possibly test the connector using an Ohm meter to make sure that the two contacts are fine. Check if an antenna adapter has been installed. In case test or replace the adapter. If the antenna connector is OK replace the antenna.
