Question about Hobart HL600 Legacy Stand Mixer
Hobart HL600 Mixer Error #13
I have Hobart HL600 Mixer. 2 days ago, I got the power outage and electricity returned quickly. After that, I see Error 13 on the timer display. I unplugged the power code and waited several minutes and plugged back in. The error code disappeared for a minute and came back, I called the Hobart service technician, and he recommended to replace whole drive(including computer board) and this will cost $1,800. I disconnected power cord for 12 hours and reconnected and tried again. Now the machine runs almost full cycle, but after 10 minutes, the Error 13 displayed again and stopped. Any advice?
Posted by Moon Lim on
2 Related Answers
bigg t
anthony james
  • 640 Answers
SOURCE: hobart hl600 mixer
I know what these codes are: code 19 is that phase c is over current fault and code 23 is a motor stall fault.I would start by making sure you 3 phase wiring going into the mixer is there.I service these mixers as im a service tech for hobart.these units are very detailed and i can walk you thru some things to check but if you have an electrical problem you most likley will have to call a hobart service tech because we have special equipment to diagnose the fault.let me know it may be something simple as these mixers are usally maintenance free.
Posted on Nov 15, 2007
Anonymous
  • 13 Answers
SOURCE: Hobart HL600 Legacy mixer will run on stir speed only.
check to see if magnet on bowl guard is still in place, it is on the right side.
Posted on Nov 15, 2008
What does 0c2 error code in Hobart mixer HL600
It is over current issue due to low supply voltage or batch size too big or frequency drive shorted.
Sep 07, 2015 | Hobart Food Mixers
We have no power out of the hl600 motor control board. whats wrong?
Because of the very high voltage on the output of the Inverter drive, I do not want to be responsible for your injury or death from you servicing this machine without proper training.
Jul 31, 2014 | Hobart HL600 Legacy Stand Mixer
Power went out then back on and mixer reads err and 12 in the timer turned breaker off then back on still reads err
Leave the breaker off for at least one minute then try it. If that doesn't take care of it then you will need to have Hobart come out and check the frequency inverter (drive).
www.hobartservice.com
May 21, 2011 | Hobart HL600 Legacy Stand Mixer
Hobart Legacy mixer error code oc3 will not run.
Hobart mixer, HL300, stops and flashes as oc3, wounded what is broken?
Dec 08, 2010 | Hobart HL600 Legacy Stand Mixer
Whats does b_9d mean. My mixer wont start to mix. The power is good but it tels me b_9d.
that fault is a b_gd.there are 10 things that can cause this.1.start sw.momentary contacts not closing. 2.stop sw. contacts open. 3.bowl guard sw. open or malfunction(b_gd)displayed on timer.4.contactor 1con malfunction.5.timerboard malfunction.6.wiring incorrect from sr drive to motor or 1con.7.sr drive malfunction 8.1 con monitor from control drive disconnected from contactor coil9.encoder malfunction 10.motor malfunction. hopefully just your bowl guard switch is no good. hope this helps, dont forget to vote, monomoy
Feb 01, 2010 | Hobart HL600 Legacy Stand Mixer
What is error code 99 for a hobart HL 600 mixer?
error 99 stands for communication fault between timer board and the sr drive.there are 5 things that can cause this error.1.rs-485 cable disconnected or malfunction 2.1 con monitordisconnected or malfunction. 3.run/stop wiring disconnected or malfunction. 4.timer board malfunction. 5.sr drive malfunction. hope this helps, dont forget to vote, thanks, monomoy
Jan 29, 2010 | Hobart HL600 Legacy Stand Mixer
HL 600 timer board I think
Sorry so late but the reason you need the kit is because the potentiometer (the knob that selects the time) is no longer part of the timer board.You need the pot,and board.I'm a hobart tech,if any other questions let me know.
Jan 05, 2009 | Hobart A200 Stand Mixer
Nov 14, 2008 | Hobart HL600 Legacy Stand Mixer
Hobart mixer
Hi,im a hobart tech and know all these mixers well.What kind of mixer are you looking to write about?The differences are the sizes of bowls as 20qt,30qt,40qt,60,qt,80qt,140qt.Pick a mixer and i will write YOUR paper,but i want a fixya rating in return.
Mar 11, 2008 | Hobart HL600 Legacy Stand Mixer
Hobart hl600 mixer
Nov 14, 2007 | Hobart HL600 Legacy Stand Mixer
Hobart HL600 Legacy Stand Mixer Logo
363 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
