eBayhttps://www.ebay.com > itm For Deep Carpet cleaner with serial # less than A13376 need to make it fit (cut out few plastic ribs). Condition. New. A brand-new, unused, unopened.
That's because you got something caught in the brush and it tore the belt (likely) or slipped off the drive portion of the motor (unlikely).
If you look at the bottom where the brush is, there are a bunch of screws to remove the bottom cover usually and can access the belt and motor to run the brush. \
belts are usually 5 to 10.00 get a pack of 2 if possible and don't do heavy rugs or get material caught in the brush lest it will happen again.. typically you can find vacuums in the trash and remove their belts, usually is only 2 or 3 types of belts so get one for free perhaps from trash.
Check to see if there is a reset button on the head. This protects the machine for times like you described. When something jms up the reset button will turn ofdf th machine. Simply push the reset. Hope this helps, Chris
You will need to pull the roller out and clean it. I think some of the strings are tangle up at the end of this roller. (Most rollers will come apart at the end for cleaning.) Make sure that the strings are not tangle up on the belt pulley as well. I hope this will help you.
there's a button lock on the top of the nozzle and the bottom of the vacuum where they meet. That should release the carpet nozzle from the vacuum cleaner easily.. you may have to jiggle it to get it loose, but there's a button lock mechanism that holds it in place
Sounds as if the v-belt came off the idler arm or you broke the v-belt. Either way, take the 4 screws out of the plate around the roller brush and make certain the belt is there and that it sits on the idler wheel. If you remove the roller brush you'll see the wheel. Pay attention to how the ends of the roller brush go back into the vacuum when inserting it and put the plate back on. Also check the thicker main belt is in place as well, it's to the left of the v-belt.
Also, the roller brush should stop when you put it in the upright position. Next time just stand it upright so the throw rug doesn't get drawn quite so far into the vacuum.
Hey there scrappy13, I would suggest you unplug the unit, turn it upside down and remove the bottom plate uncovering the brush assembly. Inside there should be a belt which drives the spinner brush. If that is in tact, then the brush itself may have been unseated when you pulled the rug out. It should be obvious to find the correct placement. Reseat, ensuring the belt is attached properly to the motor as well as the brush. If the belt has broken, a replacement is available at a registered repair facility. Good Luck!
