Question about Seloc Mercury Outboard Engine Repair Manuals SEC-1406 3-4 Cylinder 2 Stroke 1965-89
1988 mercury outboard engine has no spark from the spark plugs?
Posted by Gene Cox on
paul
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Seloc Master
  • 1,190 Answers
Swop plug/lead for one that is sparking and this will eliminate that ! swop coil for one that works etc etc ! if still not working check wires then on the power pack you can swop each coil feed !
Posted on Aug 16, 2014
DAVID PRESCOTT
  • 32 Answers
Check the coil maybe it needs replaced
Posted on Jun 05, 2012
Mercury 150hp Optimax outboard
many mercury motors use a rubber mounted prop on the shaft which is a sacrificial idea to prevent gear box damage and prop damage in with under water objects
what you suggests indicates that at certain load situations that rubber has failed and allowing the shaft to turn but is not driving the prop as required
It is driving just enough to give you steerage to get home
Sep 01, 2018 | Boating
2013 MERCURY 60HP 4STORKE OUTBOARD FIRING ORDER. REPLACED SPARK PLUGS LEFT PLUG WIRES ON COIL, COIL READ 2 3 1 4, PLUG RUN VERITICAL SO DOES #2 FROM COIL GO TO THE TOP SPARK PLUG ETC
try bottom plug on left bank
remember it is a 4 cylinder engine with the leg attached to the harmonic balancer in a car
the firing order is 1342 from the bottom end of the engine
Oct 09, 2017 | Mercury Cars & Trucks
1985 mercury 150 hp outboard V6 black-max.Where can I get a free service manual. I really only need the wiring diagrams. 1985 mercury 150 hp V6
go google and type in--- mercury outboard motor manuals --and there are pages of download manuals
if there is not one for your engine then alter the url question to --manual for mercury outboard engine 150hp v6--and see what comes up.
Sep 22, 2015 | Boating
What gap is used in 90hp mercury 1985 ,?
if you are using buhw-2 plugs then you cant gap them as they are perma gap and no electrode !
Jul 27, 2014 | Ngk Spark Plugs For Outboard Engines Plug,...
Have 115 Hp mercury outboard motor missing at full throttle and on idle. At mid throttle it is running fine. Any Idea what the problem could be. Thanks, Milton
Have your spark plugs changed AND carbs cleaned and adjusted.
Usually that can also be caused by a seized advance system ( plate under the flywheel, commanded to turn with the throttle linkage... )
Aug 16, 2013 | Seloc Mercury Outboard Repair Manual, 1965...
2stroke 8 HP mercury outboard,newish engine no spark
Clean or change the Spark Cables>
to cleab the pull them out and with antirust spray and clean
May 06, 2010 | 2009 Mercury Mariner Hybrid
Seloc Mercury Outboard Engine Repair Manuals SEC-1406 3-4 Cylinder 2 Stroke 1965-89 Logo
682 people viewed this question
Top Seloc Boating Experts
Marvin
Marvin
Bill Boyd
Dariusz Zalewski
Dariusz Zalewski
Are you a Seloc Boating Expert? Answer questions, earn points and help others
