Hoover u4259-930. I. Have this vacuum which I got from my Dad who has passed away and I have no idea how to change the Belt.
SOURCE: Belt Replacement in Hoover Savvy
go to thehooverstore site. find your machine and they'll have exploded diagrams for your machine - your should be able to tell how to replace the belt.
SOURCE: installing belt on hoover self propelled upright vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40544&thid=641399
Installing belt on Hoover self propelled upright...
Posted by Fryeburger on Jun 02, 2008
Need help installing belt on Hoover self propelled upright vacuum
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Ultra U6430-900 Wind Tunnel Bagged Upright. The best way to install the belt on a Hoover to replace one or both of the belts @ the same time for the best cleaning. The average belt change is every 4 to 6 months for best results. There is a tool that looks like a screwdriver that has a right or left angle on the end that serves as a belt puller and to hook the belt(s) onto the brushroll 1st and then take your puller and then pull or stretch the belt onto the motor pulley. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
SOURCE: hoover upright model u5095-930 belt change
I couldn't find your specific model but this may be similiar to another that you have to position the new belt around the agitator (beater bar) on the bottom of the vacuum, replace the cover, and then turn the vac over and remove the TOP cover to lift the new belt up and place it on the motor shaft/pulley. The new belt may require some effort to pull it over the pulley.
Hope this helps.
SOURCE: Installing belt
here are the step by step instructions from the owners manual for your machine.
Disconnect cleaner from electrical outlet.
WARNING: Agitator brush roll can start suddenly. Unplug cleaner before turning it over. Replacing Flat Belt Place handle in low position and turn cleaner over so bottom side is facing up. Remove the 6 screws as shown with a Phillips screwdriver. Lift off bottom plate.
Replace belt if it is stretched, cut or broken. To check the flat belt. Removing Bottom Plate Removing Belt Positioning Belt Remove used belt from large pulley and discard. Reposition bottom plate and 6 Phillips head screws. Tighten screws securely. Insert agitator brush roll through belt and position belt in groove (A) on agitator brush roll.
Inspecting V-Belt
The V-belt is designed to last for a long time and
is not normally replaced. However, if the V-belt is
cracked, gouged or broken, it should be replaced.
Slide flat belt off large pulley.
To remove V-belt, slide back of belt over pulley (A).
Then firmly pull on belt and “snap” it out.
Discard used belt.
To install new belt (with lettering on outside of
belt), slide back of belt over pulley and pull front of
belt toward groove next to pulley. Belt will “pop” into place.
Flat Belt: What to Buy
Use only genuine HOOVER belts with your
cleaner. When purchasing a new belt, ask for
Flat belt - HOOVER part No. 40201-271.
V-Belt: What to Buy
Use only genuine HOOVER belts with your cleaner. When purchasing a
new belt, ask for V belt - HOOVER part No. 40201-200.
If you can't get the answer from this post, send me a message and I will try to walk you through this. I hope it helps.
SOURCE: change belt on a hoover tempo
Remove the cover that covers the roller brush, (four screws) and remove
the roller brush and replace belt, it goes between the motor shaft and the roller brush. Replace the cover and that should do it.
Tom
